1 páginas (6 elementos)
faculty operator crashes smath - Mensajes
Wrotesee image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7
I am using the same SMath version but Win XP SP3 and cannot duplicate the crash you describe. If I follow your steps a get (a+b)!= and depending upon if a and b would have been assigned values either an error a sof "a" being unknown or the correct numeric result.
Martin Kraska 26/8/2013 1:24:00
Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash.
this is confirmed
best regards,
Davide
best regards,
Davide
WroteThanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
Yes, I can confirm that bug now.
Bug seems to be fixed, cannot reproduce it any more in 0.97.5189.
