problems with physical units and calculations
problems with physical units and calculations - Mensajes
#1 Publicado: 17/11/2022 7:27:15
rsdias
rsdias
0 me gusta en 2 mensajes.
I started using the Smath program a little while ago and I'm having a problem that I believe is because I don't know how the software works with physical units.
My problem is the following, I have a variable ton:= 6.1538 us (micro seconds), but when I do Ton^2 the result does not appear in the micro seconds unit and it stays with s^2 us unit, I don't understand how to leave it alone in micro seconds, and with that the calculation is also not correct in a formula that uses this variable ton^2, could someone tell me how this question of units works please. Thanks in advance for your attention.
#2 Publicado: 17/11/2022 10:20:18
Grupo: Moderator
Sounds like you have a non-physical equation.
If you have a = 1 m and A = a^2, then I would expect A being 1 m^2. So your physics must be very special.
#3 Publicado: 17/11/2022 10:26:03
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings!
By default, 「's」 is the base unit in SMath (and thus, the default unit of time); any calculation in terms of time will report in seconds. If you want to review your answer in microseconds, you can insert microseconds in the placeholder at the right of your equation to override the default units.
Clicking on your equation, you should notice a ▮ appear, just type the unit 「'μs」 and you will see your desired result:
Hope this helps you,
P.S. you mentioned ton and Ton in your post, be aware SMath is Case-Sensative; that is ton ≠ Ton
#4 Publicado: 17/11/2022 11:23:12
rsdias
rsdias
Thanks for the guidance, using microseconds as the unit, everything worked out fine. Thanks.
