Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - Mensajes
#21 Publicado: 28/8/2017 14:28:47
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
#22 Publicado: 28/8/2017 20:58:29
Thanks Davide for the WS.
"assume" is often needed as well as "real".
The most common is "allvalues". It expands
the more general RootOf.
#23 Publicado: 29/8/2017 7:30:28
#24 Publicado: 29/8/2017 8:13:02
#25 Publicado: 5/7/2018 6:00:06
Adriaan Knox
Adriaan Knox
0 me gusta en 25 mensajes.
I'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
#26 Publicado: 5/7/2018 8:37:52
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24,75 KiB) descargado 1100 vez(es).
Inst_PID Discrete State Systems.sm (25,51 KiB) descargado 1333 vez(es).
Inst_PID DynSys.sm (14,9 KiB) descargado 1248 vez(es).
Inst_PID [PI, PID].sm (71,51 KiB) descargado 1112 vez(es).
Inst_PID [P, PD].sm (106,94 KiB) descargado 1045 vez(es).
Inst_PID Feedback Attenuator.sm (43,76 KiB) descargado 1276 vez(es).
Inst_PID [MCD Model].sm (177,96 KiB) descargado 1111 vez(es).
Inst_TurboGen Smath.sm (106,19 KiB) descargado 1298 vez(es).
ODE_Laplace Read First.sm (27,41 KiB) descargado 1308 vez(es).
Inst_TurboGen Signum.sm (91,08 KiB) descargado 1342 vez(es).
Inst_PID Discrete Schema.sm (166,36 KiB) descargado 1338 vez(es).
ODE_Laplace 1rst [Type 1].sm (24,7 KiB) descargado 1112 vez(es).
Inst_XFR 2nd [XFR nth].sm (34,08 KiB) descargado 1115 vez(es).
ODE_Laplace 1rst [Type 2].sm (22,5 KiB) descargado 1184 vez(es).
Inst_PID DynSys_v01 (1).sm (235,59 KiB) descargado 1298 vez(es).
ODE_Laplace 2nd [Type 3].sm (33,42 KiB) descargado 1124 vez(es).
ODE Laplace Kinetic Reaction.sm (93,13 KiB) descargado 1299 vez(es).
#27 Publicado: 5/7/2018 11:11:33
Arie
Arie
94 me gusta en 285 mensajes.
Here's an example of how one might attack it.
Page1.sm (44,98 KiB) descargado 1521 vez(es).
#28 Publicado: 5/7/2018 12:58:56
Oscar Campo
Oscar Campo
Grupo: Moderator
Bravo! Alyles, simple and beautiful!!
#29 Publicado: 5/7/2018 13:04:44
You may attack for an export solution.
#30 Publicado: 6/7/2018 20:56:39
Basile
Basile
8 me gusta en 172 mensajes.
Jean,
What why the invlaplace I get a dot?
Inverse Laplace-1.sm (4,08 KiB) descargado 1344 vez(es).
Basile
#31 Publicado: 6/7/2018 21:30:07
Jean,
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
#32 Publicado: 7/7/2018 11:57:01
Basile
Basile
Jean,
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4,25 KiB) descargado 1270 vez(es).
Basile
#33 Publicado: 7/7/2018 14:28:49
Jean,
Any diagnosis?
Check from "Options" if you can fix .
#34 Publicado: 12/7/2018 20:05:19
Basile
Basile
Jean,
Can you be more specific?
Basile
#35 Publicado: 12/7/2018 23:15:48
Jean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
#36 Publicado: 13/7/2018 9:21:09
Basile
Basile
My glasses arrived!
Thank you,
Basile
#37 Publicado: 23/8/2018 20:53:31
Adriaan Knox
Adriaan Knox
After doing my best to incorporate sMath into my University workload for the past 6 months. From my magnetism class to my analog circuits class here at the University of California at Santa Cruz but it has been my experience that for every line of code I write that I generate many more while trying which are unproductive. I think the efforts made on this program are exemplary and I've donated $10 but I think unfortunately I will not be able to continue with it due to the learning curve being so steep.
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
Archivo no encontrado.Archivo no encontrado.
magnetism.zip (5,26 MiB) descargado 493 vez(es).
#38 Publicado: 24/8/2018 0:30:05
I have doctored few things in these two documents.
hw 2.6.sm (133,49 KiB) descargado 1271 vez(es).
open loop gain from closed loop gain 2.sm (48,32 KiB) descargado 1265 vez(es).
#39 Publicado: 21/9/2018 6:23:31
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93,88 KiB) descargado 1301 vez(es).
#40 Publicado: 21/9/2018 11:43:32
Enjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27,68 KiB) descargado 1329 vez(es).
