1 páginas (9 elementos)
UPDATED: RC5: SMath Studio 0.98.6123 (06 October 2016) - Mensajes
Release Candidate: SMath Studio 0.98.6122 available
Latest changes (against SMath Studio 0.98.6103)
- [SS-2409]: Return value for indeterminate argument by UnitsOf() function fixed;
- [SS-2318]: Preprocessing of symbolic data / functions' arguments finally fixed;
- [SS-111], [SS-2327]: Fixed issues with functions arguments names interference;
- [SV-2377]: Viewer: Issue when protected Area Regions was shown as tabs fixed;
- [SS-2411]: Symbolic simplification of functions arguments fixed;
- Detection of 0^0 error disabled for operations performed by numerical methods (like Integration or Gamma function);
- Function range(3) improved to fix issues with lost last value of result vector;
- Glitches happened sometimes on insert new Regions after collapsed Area Regions fixed;
- About dialog extended to show if application is started in 32/64-bit mode;
- Silent mode extended with -b argument (summary mode of output);
- Consistency fix for el(...) function - when matrix used as indices (elements by row then by column);
- Support for matrix as index feature added for sys(..) + several input errors handled;
- Refactoring.
UPDATE: Changes against SMath Studio 0.98.6122
- Support for units in range(2) implemented (base unit of the range start value used for increment);
- Automatic scrolling to the Region just added to the Worksheet improved;
- Incorrect location of Separator Region inserted by Ctrl+Enter press fixed (now it is added exactly on the place where cursor is located);
- Visual glitches fixed when using Ctrl+Click functionality to select Regions on the Worksheet;
- Special Region placeholder is now shown instead of incorrectly loaded Regions on file open;
- Refactoring and code simplifications;
- [Against to 0.98.6122 only]: Support for units in range(3) restored;
- [Against to 0.98.6122 only]: Hotkeys for Math Regions restored.
Download
SMathStudioDesktop.0_98_6123.Setup.msi (Date: 06.10.2016. File size: 2.07MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_98_6123.Mono.tar.gz (Date: 06.10.2016. File size: 1.21MB) - last version of Mono distributive required! - Cloud version (all modern browsers supported):
SMath Studio in the Cloud (Date: 06.10.2016.)
A 8 usuarios les gustó este mensaje
NDTM Amarasekera 5/10/2016 16:15:00, Radovan Omorjan 5/10/2016 17:55:00, Mike Kaganski 5/10/2016 18:23:00, bdrunagle 5/10/2016 18:50:00, Davide Carpi 5/10/2016 18:57:00, Вячеслав Мезенцев 5/10/2016 23:16:00, sergio 6/10/2016 4:48:00, Василий Николаевич Храмушин 6/10/2016 10:29:00
Problems with "[", "]", "\" and units in range are fixed in appVersion(4)="0.98.6123.7493"
С уважением,
Михаил Каганский
Igor Skarine 6/10/2016 10:29:00
Thank you Mike!
Yes, issues you have found are fixed (not only thoose ones) and new build created.
Please see updated first comment for list of changes.
Best regards, Andrey Ivashov.
Hello.
In Windows version I insert image on the document page and save it. After I open this document on the Linux and don't see image. But on Windows image be show.
(Sorry for bad English)
WroteHello.
If it is related to the "Image Region" please post in the corresponding thread of the plugin - I will attempt to help you.
