Matrix Data
Matrix Data - Getting the wrong information - Mensajes
#1 Publicado: 12/4/2018 16:33:22
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
I need the information for 1 pipe diameter smaller ... sigh, I hate programming
PipeVel.sm (10,74 KiB) descargado 1148 vez(es).
#2 Publicado: 12/4/2018 18:57:52
Smath is like Mathcad ... etc almost dead w/o programmed utilities.
#3 Publicado: 12/4/2018 20:43:16
I hate programming
Model your pipe from inspired working document.
Inst_Colebrook Pipe Data.sm (59,38 KiB) descargado 1231 vez(es).
#4 Publicado: 13/4/2018 16:45:34
CBG
CBG
78 me gusta en 312 mensajes.
Here is a solution
PipeVel_CBG.sm (8,94 KiB) descargado 1224 vez(es).
Carlos
ElSid 13/4/2018 17:33:00
#5 Publicado: 13/4/2018 17:18:30
Ruben Sidranski
Ruben Sidranski
Muchas gracias Carlos. Lo que no podia ver es la indice else --> index.j:1 Handaba pensando en algo similar para retener el numro viejo, pero nada se me vino a la mente.
Ruben
#6 Publicado: 13/4/2018 17:25:39
CBG
CBG
No hay de que Ruben. Recibe un cordial saludo.
Carlos
#7 Publicado: 13/4/2018 22:01:39
CBG
CBG
Ruben: A slightly more complicated algorithm, which supports several speeds and several flows.
PipeVel_CBG_R1.sm (14,85 KiB) descargado 1242 vez(es).
Carlos
#8 Publicado: 14/4/2018 10:07:09
Ruben Sidranski
Ruben Sidranski
Interesting. I was looking at modifying your other code ... this is better inspiration.
I'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe dia, at a higher flow. With your original code, I set this up in two steps to look at VFD driven system.
#9 Publicado: 14/4/2018 14:58:53
I'm looking at sizing pipe at low flow, then calculate velocity, fixed pipe ID, at a higher flow.
TW, Tanks Carlos ... lovely code.
Elsid, about your request:
That's what "Colebrook Pipe Data" [post 3] does.
1. For industrial projects, we measure MassFlow, not volumetric
... volumetric is for simple/primitive municipal water work.
2. "Colebrook Pipe Data" in based on 100 m, pipe length.
3. Pipe sizing is like valve sizing: trial/error,
... mostly wrt "Nominal" design conditions.
4. Convert your input data from SI to US
5. post convert back from SI to US.
#10 Publicado: 15/4/2018 10:17:34
Ruben Sidranski
Ruben Sidranski
Jean,
I tend to deal in "volumetric is for simple/primitive municipal water work." And hydronic systems.
#11 Publicado: 15/4/2018 10:52:33
Jean,
Hydronics is the use of water as the heat-transfer medium in heating and cooling systems. A hydronic piping system is used to circulate chilled or hot water with the connections between the piping and the terminal units made in a series loop.
Whatever "Hydronic" is hot/cold, the water has properties wrt to MASS.
Reverse Engineering in your proposal does not solve project not understood from the onset.
