SMath Studio 0.99.6638 (05 March 2018) - Mensajes
Ofrece numerosas funciones de cálculo y una interfaz de usuario completa, traducida a unos 40 idiomas diferentes. La aplicación también incluye una obra de referencia matemática integrada.
La aplicación puede ampliarse fácilmente según sus necesidades. La herramienta integrada de gestión de extensiones permite acceder a cientos de recursos, tanto oficiales como de terceros, que incluyen: ejemplos de uso, complementos (plug-ins), aplicaciones basadas en SMath Viewer, fragmentos de código, traducciones de la interfaz, libros interactivos, manuales y tutoriales.
Descargar
SMathStudioDesktop.0_99_6638.Mono.tar.gz (1,28 MiB) descargado 2645 vez(es).
SMathStudioDesktop.0_99_6638.Setup.msi (2,15 MiB) descargado 5144 vez(es).
Utilities Matrix_Vector [MCD 4 styles].sm (34,65 KiB) descargado 1501 vez(es).
WroteEvery time Smath Studio is updated, something goes wrong.
Yeah, its a life...
Fixed (please update a plug-in). Thank you!
Thank you very much.
Carlos
That's why I'm 6179 for productive projects.
WroteWroteEvery time Smath Studio is updated, something goes wrong.
In this case you have to live with slow performance, tens of critical known (and already fixed) bugs. You can't use new features and make your future switch to newer version harder. There is no even any guarantee that your worksheets can be supported by latest SMath Studio versions (yeah, in SMath history we had couple of such situations when a part of calculation can not be handled anymore, unfortunately).
So, I can't say that it is good approach.
Archivo no encontrado.Archivo no encontrado.
WroteA bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638
That it was introduced between 6617 & 6638, that is surprising ?
Even if it did work, to me, it is not correct because it will cause
something wrong sooner or later, because to reflexive in the
calculation kernel ... Murphy's law. I have experimented disastrous
situations [crash ... push the button to stop].
Occasionally, to isolate, you have to spool to file.
Cheers Alex ... Jean
WroteA bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638. Will this be addressed?
Jean are right, this didn't work initially, but started working at some point because of another bug
I've investigated this example and was able to make it work together with all other examples I have about vectorize(..) function. All tests executed OK.
So, I decided to include this improvement into new release: https://en.smath.info/forum/yaf_postst12594_RC-0-99-6648--15-March-2018.aspx
Please test examples you have with vectorize(..) function.
