1 páginas (9 elementos)
See the result on the place where the variable is defined - Mensajes
I have two little questions.
First if I defined a=5 and b=10, and then if I write c=a+b, is it a problem to see the result in this way c=a+b=5+10=15.
Or the same question but c=a+b=15.
It is a visual problem, but would be helpful
Thanks in advance.
Greetings
Thanks in advance.
Greetings
Sorry, that I did not check the older topics, but at least that means that this is a wanted feature.
Absolutely yes... I think that The only definition + result, without numerical expansion, would be a fantastic improvement....
Can, then, we have a second option to horizontal alignment, a vertical one?
F = m*a = 10 kg * 2 m/s^2 = 20 N
F = m*a
= 10 kg * 2 m/s^2
= 20 N
Thank you,
Basile
F = m*a
= 10 kg * 2 m/s^2
= 20 N
Thank you,
Basile
Does the Maxima plugin work with a portable installation of Maxima? (I have wxMaxima from WinPenPack) Or else, Can you manually set the path to find Maxima?
