Solving an eqaution
Solving an eqaution - Mensajes
#1 Publicado: 15/9/2021 10:22:58
Necronomicron
Necronomicron
0 me gusta en 8 mensajes.
Hello!
I have an equation (sphere and cubic Bézier curve intersection points): B(t) ⋅ B(t) = r², where dot means vector dot product.
B(t) is a cubic Bézier curve:
B(t) = (1 − t)³ ⋅ P0 + 3t ⋅ (1 − t)² ⋅ P1 + 3t² ⋅ (1 − t) ⋅ P2 + t³ ⋅ P3, 0 ≤ t ≤ 1
P0, P1, P2, P3 are some known points, к is some known value too.
Is it possible to solve this using SMath while keeping constants as letters?
#2 Publicado: 15/9/2021 11:08:25
Please attach your Smath document.
Bézier/Hermite ... lot in Smath.
#3 Publicado: 15/9/2021 11:49:13
Necronomicron
Necronomicron
https://ru.smath.com/cloud/sheet/ao2a4mLPSz
Well, not much in there, I don't know how to write the equation in it. I am new to SMath, and used only MathCAD a few times, like, 13-14 years ago...
#4 Publicado: 15/9/2021 12:19:37
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
"Error. There is no Worksheet found."
Please upload your sm file to any cloud service a share the link
Oscar
#5 Publicado: 15/9/2021 12:24:03
Necronomicron
Necronomicron
Sphere and cubic Bezier curve intersection points.sm (10,28 KiB) descargado 1265 vez(es).
Oscar
#6 Publicado: 15/9/2021 13:00:26
Oscar Campo
Oscar Campo
Grupo: Moderator
You must use Symbolic evaluation to solve your equation, additionally, you can use some plugin for this task (in my case I used the Maxima plugin).
Please see attached file:
Sphere and Cubic.sm (215,02 KiB) descargado 1249 vez(es).
#7 Publicado: 15/9/2021 14:21:28
Grupo: Moderator
All those kind of symbolic solvings require either Maxima or Maple plugin as far as I know.
Every other smath solvers [solve(), roots(), FindRoot(), al_nleqsolve(), etc] are numerical solvers.
Could someone correct this statement if it is not true?
#8 Publicado: 15/9/2021 14:33:35
Oscar Campo
Oscar Campo
Grupo: Moderator
Every other smath solvers [solve(), Roots(), al_nleqsolve(), etc] are numerical solvers.
yes, that's correct, you can check the description of solve(), roots(), al_nleqsolve(), etc on the Interactive SMath Handbook
#9 Publicado: 15/9/2021 20:57:18
Hi. In the attached how to solve the problem numerically. Notice that B(t) must to be defined using vectorize, because SMath don't expand the scalar by vector products.
Sphere and Cubic.sm (8,86 KiB) descargado 1205 vez(es).
Oscar Campo 15/9/2021 21:07:00
#10 Publicado: 16/9/2021 6:43:49
Necronomicron
Necronomicron
There is missing «²» after second parentheses in your file. And I downloaded SMath and Maxima, but when I open your file, I get an error: «Cannot find maxima.bat».
Sphere and cubic Bezier curve intersection points.sm (3,77 KiB) descargado 1290 vez(es).
#11 Publicado: 16/9/2021 7:33:52
Oscar Campo
Oscar Campo
Grupo: Moderator
Please refer to Maxima plugin instructions, you can find here
#12 Publicado: 16/9/2021 8:18:04
Necronomicron
Necronomicron
OK, I've fixed the error, but now it says: «r is undefined». Sorry, it's really hard to understand what to do and I can't find any proper docs about it...
Sphere and cubic Bezier curve intersection points.sm (4,62 KiB) descargado 1263 vez(es).
#13 Publicado: 16/9/2021 8:43:30
Necronomicron
Necronomicron
I really don't get what's wrong now...
Sphere and cubic Bezier curve intersection points.sm (12,04 KiB) descargado 1290 vez(es).
#14 Publicado: 16/9/2021 9:40:26
Oscar Campo
Oscar Campo
Grupo: Moderator
There is a missing "*"
#15 Publicado: 16/9/2021 11:07:40
Necronomicron
Necronomicron
Thank you! But what should I do with «r is undefined»? 🤔
#16 Publicado: 16/9/2021 11:12:25
Oscar Campo
Oscar Campo
Grupo: Moderator
Are you sure you are using the option "Symbolic Optimization"?
You must right-click over your equation, then choose Optimization-Symbolic
#17 Publicado: 16/9/2021 11:40:06
Necronomicron
Necronomicron
Thank you very much! It worked! However, the roots are so long... Not sure I can use them... Thanks anyway! 😊
#18 Publicado: 16/9/2021 14:52:16
Hi. Notice that P0, ..., P3 are vectors with 3 components, not scalars. You can't get the distance with B(t).B(t) using P's as scalars.
#19 Publicado: 16/9/2021 20:16:44
Didn't see the sphere ?
Bézier is a 2 D plot
I don't understand your project, will leave.
You can project Bézier as surface plot on the sphere,
at this point, all 'N' are roots.
Enjoy/ignore ... Jean.
Page6 Bezier.sm (30,64 KiB) descargado 1465 vez(es).
#20 Publicado: 16/9/2021 21:20:45
Grupo: Moderator
Not related with topic. Nice example to Bezier however no relation with question.
Seeing Bezier in question doesn't mean you can search your files and post your first match Bezier example.
fedeghi 17/9/2021 3:24:00
