1 páginas (4 elementos)
How to Hard Define a Variable with Combobox - How to set a variable equal to a value as if manually input using a combobox - Mensajes
I like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!!
Thanks!!
Interesting, but "Insert Combo box" crashes Smath 5346 ! ?
Davide Carpi 13/2/2016 7:25:00
WroteI like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!!
As for now there aren't workarounds from user-side. Probably a dirty solution (DEV-side) would be to provide an access to the output values in the xml with an "hook tag" for include. However the content wouldn't be "dynamical".
WroteInteresting, but "Insert Combo box" crashes Smath 5346 ! ?
Merci beaucoup Jean, bug confirmed, source of the pain found. I'll update the plugin ASAP.
I see, I'll keep watch for any updates.
Thanks!
Thanks!
