Country flags - x-yplot fill - Mensajes
Let's make this a challenge, upload your country flag under this post.
Here is my country's flag totally accurate to our flag standard.
flag_tr.sm (9,52 KiB) descargado 1809 vez(es).
The flag design of my country is very simple, so I add some waves to make it more interesting.
flag_CO.sm (14,29 KiB) descargado 1746 vez(es).
Regards!!
WroteHi, for some reason the flag is not filled as it is shown?
also, I noticed that the "properties source" in the formatting options is gone now, so how can we adjust the max/min and ticks by code?
Thanks
this is how it shows on my version now (V1.2 built 9018 dated 09-sep-2024)
this is the old version where the "properties source" is shown
this is the flag with no fill:
You must to update the X-Y Plot Plugin
svg_uy_flag.sm (299,02 KiB) descargado 1855 vez(es).
WroteHi Overlord. My contribution too. If the flag is not too complicated you can try programming its path using SVG commands in SMath with this file (taken from here, but due to the bug with <, > and & it no longer works well). Or simply use the text with the SVG commands and display it in an image component:
Hi Alvaro,
I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (287,69 KiB) descargado 1811 vez(es).
Best wishes,
Oscar
WroteHi Alvaro, I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (287,69 KiB) descargado 1811 vez(es).
Hola Oscar. Gracias!
Un abrazo.
Here is my candidate:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
