Using the random function
Using the random function - Mensajes
#1 Publicado: 26/6/2010 3:26:24
Brian Runagle
Brian Runagle
13 me gusta en 27 mensajes.
Hi
I have a problem using the random function.
If I assign a random number to a variable, x=random(6) for example, and look at the value once I see a value, say x=4. If I look at it again I get a different number, say x=2, and so on. It's as if looking at the variable x calls the random function again.
This also occurs in SMath Live.
The question is then, how can I "freeze" the value of x so that I can work with a random value without it changing every time I look at it?
Many thanks
Brian
#2 Publicado: 26/6/2010 14:35:56
Grupo: Moderator
Hello Brian,
Just select the region x=random(6) and right clik on it. Choose Optimization=>Numeric. After that you can work with the random number, and x random value is "freezed" then. If you want to use another random number just Recalculate page (F9)
#3 Publicado: 27/6/2010 2:09:48
Brian Runagle
Brian Runagle
Thanks Radovan, that's just what I wanted.
Brian
#4 Publicado: 27/6/2010 2:57:18
Grupo: Moderator
You are welcome
I suggest you to use SMath Wiki and, of course, to use this Forum in order to express your opinion how to improve SMath or to report bugs as well.
