Hydraulic calculation of the pipeline
Hydraulic calculation of the pipeline - Mensajes
#1 Publicado: 6/11/2021 13:46:38
Tolik
Tolik
0 me gusta en 7 mensajes.
Hello.
I just started to study the program on my own.
And I don’t know how to build dependency graphs V(Q), Re(Q), lambda(Q) and delta p1 (Q) (see the file).
Сan you help with advice?
Thanks in advance.
Raschjot gidrolinii.sm (17,32 KiB) descargado 1234 vez(es).
#2 Publicado: 6/11/2021 15:38:53
Maybe Colebrook will help to complete your document.
Raschjot gidrolinii [incomplete].sm (18,45 KiB) descargado 1077 vez(es).
Inst_Colebrook Pipe Data.sm (71,45 KiB) descargado 1216 vez(es).
Tolik 6/11/2021 16:41:00
#3 Publicado: 6/11/2021 16:42:30
Tolik
Tolik
Thank you for the help
#4 Publicado: 6/11/2021 16:49:50
Grupo: Moderator
Here is a tip to your projects.
SMath vector/matrix/array indexes start from 1, not 0.
That will cause problems on your worksheets.
If you are rewriting a page from mathcad or similar, keep this in mind.
Tolik 7/11/2021 6:23:00
#5 Publicado: 7/11/2021 6:29:25
Tolik
Tolik
Thanks for the help.
I found another mistake.
Everything works now.
Now I'm trying to plot graphs...
Raschjot gidrolinii.sm (1,68 MiB) descargado 1297 vez(es).
#6 Publicado: 7/11/2021 8:16:26
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
Changed the code a little and built a variant of the graphs
Raschjot gidr.sm (40,2 KiB) descargado 1258 vez(es).
Tolik 7/11/2021 10:01:00
#7 Publicado: 7/11/2021 10:38:05
Tolik
Tolik
Your solution is very beautiful
#8 Publicado: 7/11/2021 10:39:02
I saved in my personal file.
Check Δp ... it looks bizarre.
Inst_Colebrook PipeLine [unk].sm (19,78 KiB) descargado 1052 vez(es).
Tolik 7/11/2021 11:21:00
#9 Publicado: 7/11/2021 11:26:11
Tolik
Tolik
Thank you, Jean. You're right
I understand.
Because Lambda is calculated using three different formulas.
Interpolation is also needed.
But overall the solution looks right.
Best regards, Tolik
#10 Publicado: 7/11/2021 12:25:28
Tolik
Tolik
Approximation in this case
#11 Publicado: 7/11/2021 14:25:11
I understand.
Best regards, Tolik
Nothing wrong to adapt third segment for a smooth junction,
or simply ignore for elongating 2nd segment.
Take care ... Jean.
Inst_Colebrook PipeLine [unk].sm (24,9 KiB) descargado 1030 vez(es).
Tolik 8/11/2021 18:22:00
#12 Publicado: 8/11/2021 8:52:26
I understand.
Best regards, Tolik
I think you should initialize λ1:=64
Δp interpolation is straightforward as given.
λ interpolation will surely need Thiele.
Please, let me know if you want λ interpolation.
Have a good day Kamarad ... Jean.
#13 Publicado: 8/11/2021 12:21:01
λinterpolation will surely need Thiele.
All your data sets have been converted to scalar functions.
Thiele is exceptional for Lambda.
By observation, Delta P needs better adjusting
segment 1 and segment 2 ... refine 2/3 junction.
All that done, it remains specific as demo, is it ?
Inst_Colebrook PipeLine [unk].sm (266,8 KiB) descargado 1067 vez(es).
#14 Publicado: 8/11/2021 14:08:11
... project refined for your comments.
Have a good visit ... Jean.
Inst_Colebrook PipeLine [unk].sm (267,71 KiB) descargado 1062 vez(es).
#15 Publicado: 8/11/2021 18:20:13
Tolik
Tolik
Sorry. I do not know the program well enough to properly evaluate your modifications and amendments.
You did a great job in my opinion.
In fact, the pressure will undergo two transitions.
The first transition: the destruction of the laminar flow and the appearance of the first large vortices.
The second transition: the core of the flow begins to touch the tops of the roughness of the pipe walls.
But I don't know exactly how they will affect the graph..
Yes, at this stage I needed to get a rough solution.
This is only the first section of the calculation of the system.
There are four of them.
Moreover, at the end, the pipeline has a branch. As a result, the solution is expected to be quite long.
Best regards, Tolik
#16 Publicado: 8/11/2021 19:49:49
Best regards, Tolik
Perpendicular branches create singular losses.
Better conserve this refreshed version.
Nice project ... Jean.
Inst_Colebrook PipeLine [unk].sm (88,36 KiB) descargado 1071 vez(es).
