1 páginas (3 elementos)
Unexpected behavior - Mensajes
Hi. I can not understand why the argument of the last function "disappears"
Thanks in advance
Archivo no encontrado.Archivo no encontrado.
Thanks in advance
The answer is in dec2bas(x,b).
In the third row there is x
x-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0).
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z
z-m)/b)
sergio 23/8/2018 13:04:00
WroteThe answer is in dec2bas(x,b).
In the third row there is xx-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0).
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> zz-m)/b)
Tante grazie Davide! I did not know where else I could look for the error, because I thought I had reviewed everything.
Davide Carpi 23/8/2018 20:52:00
