1 páginas (3 elementos)
How to expand a matrix? - Mensajes
How to expand a 2*2 matrix to a 3*4 matrix?
You can simply define a value for an index out of the existing range, the matrix will be expanded to contain that new element.
example
example
netsonicyxf 29/3/2025 16:18:00
Greetings,
The easiest way to expand a 2x2 is to select the matrix; you will note a black handle at the bottom-right hand corner; just click'n-drag to the larger 3x4 matrix.
per the help:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
per the help:
If you change your mind about dimensions you can always change the matrix dimensions. Just click inside the matrix on the right lower corner. The black square with a vertical and horizontal line will appear. With the left mouse button (mouse pointer will change the appearance) drag and correct the dimensions. You can do that even if the placeholders are not empty,
https://smath.com/wiki/Print.aspx?Page=Matrices
netsonicyxf 4/4/2025 20:16:00
