Operation with units xy2pol
Operation with units xy2pol - Mensajes
#1 Publicado: 5/6/2016 0:07:03
Basile
Basile
8 me gusta en 172 mensajes.
The xy2pol looks that still has problems with units:
Basile
#2 Publicado: 5/6/2016 13:34:47
#3 Publicado: 5/6/2016 13:53:42
Basile
Basile
Jean,
In your example:
The Magnitude (length) and The Angle (angle) in polar coordinates have different units. The rad is not a common unit. It is not correct.
In my example:
Look again please:
This was solved in recent upgrade by Andrey but apparently remains in the xy2pol.
http://en.smath.info/forum/yaf_postst7552_Units--Operation-cannot-be-performed.aspx
Basile
#4 Publicado: 5/6/2016 15:14:46
Better be in harmony wth the maths and Smath.
There is nothing to look gain, Smath is OK.
For sure they have different units: one is in "UnitGraph" the other is in "rad"
YES: rad is correct, rad is the maths unit in trig approximations as well as in official tables.
If you want °: convert by appending ° in the Smath result
#5 Publicado: 5/6/2016 17:22:05
Basile
Basile
Jean,
1.
Please go previously and see the picture.
"rad" is the unit for both the magnitude and angle.
There is ONE placeholder for ONE unit.
YES: rad is correct, [YOU JUST SAID THAT ONE IS LENGTH THE OTHER ANGLE!!!] rad is the maths unit in trig approximations as well as in official tables.
2.
In this specific set of applications I have no interest in "numerical MathEMATICS". I use units. Thank you.
Basile
#6 Publicado: 5/6/2016 17:38:16
Mike Kaganski
Mike Kaganski
184 me gusta en 434 mensajes.
@Basile,
Just show what you are trying to describe verbally
Not that it would convince anyone who doesn't wish, though.
С уважением, Михаил Каганский
Davide Carpi 7/6/2016 17:28:00
#7 Publicado: 5/6/2016 17:52:10
Basile
Basile
Mike,
The xy2pol does not work when units are included:
Do we agree?
When eventually it is working:
The units of the "Magnitude" and the units of the angle, (for the case of complex numbers here), will be different.
Note: I see you got W(att) how?
I see that you have a semicolon ( ; ) I have a comma (,).
Re(S);Im(S) versus Re(S),Im(S)
Basile
#8 Publicado: 5/6/2016 19:26:10
Something like that?
Notice that atan2 ins't in SMath, which is more correct than atan for this functions (see http://www.mathworks.com/help/matlab/ref/atan2.html for example).
Davide Carpi 5/6/2016 19:28:00
#9 Publicado: 5/6/2016 19:55:50
Mike Kaganski
Mike Kaganski
Mike,
Do we agree?
Yes we do
Citar
Yes, that's what I show in my screenshot, that uses ≡ instead of =, just to show the desired result: seeing is better than reading.
Citar
Now I suppose it's apparent: Ctrl+= and manually make system with desired result
Citar
Russian locale default settings
#10 Publicado: 5/6/2016 19:57:34
In this specific set of applications I have no interest in "numerical MathEMATICS". [Basile]
From A...Z, Smath is a numerical math tool as any other CAS and including your specific application.
xy2pol result is a vector of two components that need no unit as they are implicit. Extract each
component and append a dead unit decoration for clarity to yourself and the reader.
#11 Publicado: 5/6/2016 20:03:39
Mike Kaganski
Mike Kaganski
atan2.sm (35,42 KiB) descargado 1296 vez(es).
#12 Publicado: 5/6/2016 20:58:58
Hi Mike. I prefer this other, but have some round inconvenients:
Archivo no encontrado.Archivo no encontrado.
#13 Publicado: 5/6/2016 21:04:35
Mike Kaganski
Mike Kaganski
I guess that with the new try function samebody can make a good one atan2.
But with try, it won't differentiate again.
#14 Publicado: 5/6/2016 21:10:02
Oh, I think that this happen only to me :-). Not very sure that try don't accept diff.
So, this with numerical optimization must to be the best solution (until atan2 not be in SMath):
#15 Publicado: 5/6/2016 21:24:33
Mike Kaganski
Mike Kaganski
It's a good option, and only ~30% slower.
#16 Publicado: 6/6/2016 10:11:40
Like this Alvaro: look for the Matlb code in the f(x) menu,
look for mwatan2 ... if you have in your version: then go
Maths atan2.sm (10,93 KiB) descargado 1359 vez(es).
