Select from file
Select from file - Mensajes
#1 Publicado: 25/6/2015 5:09:58
dansuciu
dansuciu
0 me gusta en 1 mensajes.
Hi there,
I have a large amount of initial data, that can vary depending on many conditions.
Each initial parameter has a set of parameters specific to it. i.e. concrete class C6/7.5 has a different compresive strength than C8/10 and so on
Of course, i want to create my algorithm as parametric as possible.
I was thinking of making some tabular data for them, but not sure if i can make smath read from another file, as to make the final file with results as clean as possible.
Any help or suggestion is appreciated.
Thank you.
#2 Publicado: 25/6/2015 12:10:52
Ernesto
Ernesto
13 me gusta en 74 mensajes.
You can try playing around with the ComboBoxList Extension. Attached is an example.
Expand the area to see the data I used.
Double click on the ComboBoxList region to see settings.
Davide Carpi 25/6/2015 15:05:00
