Data Table Parsing Function - Intelligent VLOOKUP()
Data Table Parsing Function - Intelligent VLOOKUP() - Mensajes
#1 Publicado: 2/1/2017 21:33:38
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
I would like to share an example of function that extracts rows from a data table based on set value in selected columns:
VLOOKUPdataparse.sm (17,57 KiB) descargado 1279 vez(es).
Davide Carpi 3/1/2017 6:54:00, francesco rapuano 31/12/2024 0:37:00
#2 Publicado: 2/1/2017 21:39:38
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
I do need help with an interesting behaviour of a matrix definition:
If an element of a defined matrix contains a user defined function with an undefined parameter it may inthrow an error similar to here (same SMath file as above):
I would expect the function with undefined parameter to return itself instead of giving an error code.
#3 Publicado: 3/1/2017 7:06:30
Grupo: Moderator
Very nice
I think the issue comes out because there isn't a way to stop the preprocessing in user-defined functions when you pass an unknown (and an unknown is not a valid input).
A workaround that might be useful even to avoid the use of other functions is to use a string as input in the second row, and a check in your lookup like this:
frapuano 3/1/2017 10:44:00, Alexander O. Melnik 3/1/2017 8:45:00
#4 Publicado: 3/1/2017 9:06:46
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Davide,
Is the a reason why function like findstr() does not return itself when not all variables are defined? Similar to this:
http://en.smath.info/forum/yaf_postsm36158_cases-in-definition-of-a-function.aspx#post36158
Also I am not sure if this is similar, but after I modified my excel_IO() function to return FALSE if undefined variables were present it would preprocess correctly with undefined variables when passed as an argument to a user defined function (you and I had an email discussion about this).
P.S.: the reason why a more general solution is desired is because a one might want to implement a more complex boolean check, than <>=!
#5 Publicado: 3/1/2017 12:37:22
Grupo: Moderator
It is by design. However even returning itself, you will have always var=findstr(...) -> false -> ... (it doesn't prevents the strcont() function to be evaluated)
Yes, but with functions created on the canvas this isn't possible
You can try with this:
strcont() is defined locally to avoid the preprocessing on the canvas
try() function is added because when you use el(...) inside the lookup function, all the elements of the condition matrix are evaluated -> you have to allow any type of input as first argument or let it fails silently (because strrep requires strings); note that if the selected element of the condition matrix is the one that contains strcon() with a wrong type as first argument, the error string will trigger an error on bool#:eval(bool#*operand#), because operand# will be a string.
Alexander O. Melnik 3/1/2017 12:41:00, frapuano 3/1/2017 14:55:00
#6 Publicado: 3/1/2017 15:06:28
Alex,
The attached proposal is for fixed "credit".
It might be ranged via bolean.
Alex VLOOKUPdataparse.sm (33,69 KiB) descargado 1331 vez(es).
Alexander O. Melnik 3/1/2017 15:37:00
#7 Publicado: 3/1/2017 15:37:30
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Alex,
Thanks, Jean. I havent used "truth tables" yet; they seem to work quite well.
#8 Publicado: 6/1/2017 20:53:23
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Is there a quicker way to assemble a SMath matrix from rows than stack()?
In vb.net I can assemble 13x10000 SMath matrix in 3.3 seconds (excel_OUT), while stacking of 488 rows (13 elements each) into matrix within SMath takes 21 seconds
Thanks!
#9 Publicado: 9/1/2017 7:49:47
Grupo: Moderator
Hello Alex, can you attach an example where stack it is so slow?
#10 Publicado: 9/1/2017 10:31:18
Alex,
It depends what you assemble, and how.
Three examples attached.
Alex Assemble Matrix.sm (32 KiB) descargado 1225 vez(es).
#11 Publicado: 9/1/2017 13:52:25
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Here it is - I use EXCEL to input 10000 x 13 matrix into SMATH - 1.2 seconds. Vlookup() loop to stack 400 rows - 15 seconds. Vlookup() loop which does not stack anything is 3 seconds.
VLOOKUPslow.sm (27,05 KiB) descargado 1246 vez(es).
DATA.xlsx (1,61 MiB) descargado 1001 vez(es).
#12 Publicado: 9/1/2017 21:06:51
Grupo: Moderator
Try this; basically removes all stack() calls to build the matrix after you check all the conditions. On my notebook is 50% faster than your.
VLOOKUPfast.sm (31,5 KiB) descargado 1387 vez(es).
Alexander O. Melnik 9/1/2017 21:14:00
#13 Publicado: 9/1/2017 21:13:40
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Much better, thanks.
Could you explain how does the following exactly work:
resultrng#:el(data#,matches,range(1,cols(data#)))
#14 Publicado: 9/1/2017 21:32:49
Grupo: Moderator
You're welcome
It is this feature; in the 2nd argument of el(3) there are all the rows I want from first argument's matrix, as 3rd argument all the columns. The result is a matrix of the elements that fits both the requirements, in the given order.
#15 Publicado: 23/4/2021 0:20:54
xsynt
xsynt
0 me gusta en 1 mensajes.
thank you for sharing these function, lookup is another essential features of spreadsheet and could be better if it has to be include in standard distribution.
from vlookupfast.sm modification, may it be simplified for such a situation below. in case condition only use boolean 'equal to' as the same in any spreadsheet function.
#16 Publicado: 23/4/2021 15:29:41
There area dozen of lookup. If so many for so many applications.
Be more specific c/w *.sm document.
#17 Publicado: 23/4/2021 15:36:59
... visit this intelligent/advanced lookup.
Utilities Matrix Locate Array1 Array2.sm (70,25 KiB) descargado 1282 vez(es).
