1 páginas (11 elementos)
Pulses and Waveforms - MCad - SMath Studio - Mensajes
Hello SMATH Forum,
I recently came across a set of MathCad sheets, which I am attempting to extract a small sample; rectified waveform and ripple. As I am trying to reconstruct in SMath, early on, I cannot resolve a few definitions; functions "rect1(...)" and "g1hw(...).
I'm hoping someone can help. Attached is my SMath sheet and the reference MathCad15 files.
Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.
I welcome your review and look forward to your reply.
Sincerely,
Norm
Sincerely,
Norm
The *.sm document does not open ... PDF YES
Play with these two ... Jean
Page5 Norm.sm (20,55 KiB) descargado 1404 vez(es).
... added numerical convolution.
From brushing the *.PDF "pulse" has no limit.
Show some you need for concluding a project.
Page5 Norm.sm (26,84 KiB) descargado 1358 vez(es).
Pulses and Waveforms work in progress.sm (679,02 KiB) descargado 1272 vez(es).
Thanks Jean! I hope the attached works now.
The function g1hw fails. The comment "k - not defined". Hopefully, the attached pdf of my fist page give you an idea. Pulses and Waveforms work in progress - nas.pdf (129,72 KiB) descargado 752 vez(es).
Best regards,
Norm
Best regards,
Norm
Hi Norm. Some few notes:
- For speed up the code, you must to put at some places some eval() in SMath.
- Some vectorization are automatics in Mathcad, but not in SMath. Here you can use the index nk instead implicit or explicit vectorization, as shows the picture.
- N0.gc is 2^8, and it is for use as the finite index for fast Fourier sums, but it's too big for SMath. Use something lower.
- T.hw is undefined in you worksheet.
Many thanks Alvaro & Jean,
As always, I appreciate your high-level knowledge using this fantastic tool!
Stay safe and take care.
Sincerely,
Norm
Sincerely,
Norm
Work in progress...
I gave up on the MathCad "Pulses and Waveforms" conversion.
The attached sheet is not complete, just my attempts at the graphs thus-far. I'll need to spend some time working in the diodes conduction range.
Anyway, using the discharge profile looks close, not correct, but has a close resemblance.
Best regards,
Norm
Single-phase full-wave bridge rectifier circuit with C-filter and resistive load.sm (338,44 KiB) descargado 1297 vez(es).
Best regards,
Norm
WroteI gave up on the MathCad "Pulses and Waveforms" conversion.
This one is above my head.
On the other hand, Smath depends largely upon "plugins"
and they don't behave all same, i.e: Fourier stuff.
In the mean time, you can visit these 4 examples.
Convolution RC 6179.sm (13,87 KiB) descargado 1200 vez(es).
Convolution Numerical [Pulse model].sm (26,48 KiB) descargado 1019 vez(es).
Convolution Pulse Integration.sm (31,68 KiB) descargado 1193 vez(es).
Laplace Admittance Analyzer.sm (1,03 MiB) descargado 1329 vez(es).
Thanks Jean! I'll look at this.
Best regards,
Norm
Best regards,
Norm
