3D Plot Region (Chart3DLib)
3D Plot Region (Chart3DLib) - Problem with saving formatted plots - Mensajes
#1 Publicado: 4/10/2020 22:05:04
Dariusz Pogocki
Dariusz Pogocki
0 me gusta en 3 mensajes.
For my Physical Chemistry lectures I am adopting MathCAD 8th sheets attached to the Atkins and de Paula, 7th edition textbook, to the recent SMath Studio. For 3D plots I am applying plugin "3D Plot Region (Chart3DLib)" it works good except saving formatted plots. Have you got any idea how to resolve the problem.
The SMath sheet and PDF screen attached.
Yours
Dariusz.
Archivo no encontrado.Archivo no encontrado.
#2 Publicado: 5/10/2020 9:49:53
Grupo: Moderator
This is a version using the draw function of the Maxima plugin. The commands are described and demonstrated in Section 6.1 of the german SMath Handbuch
P701E02_Kr.sm (224,5 KiB) descargado 1649 vez(es).
#3 Publicado: 5/10/2020 11:36:26
Dariusz Pogocki
Dariusz Pogocki
Thanks Martin,
Now I have to overcome the "no maxima.bat" problem. .
Your solution allows rotation of the plot?
Dariusz
#4 Publicado: 5/10/2020 13:24:49
Grupo: Moderator
For configuring maxima, see the link in the signature.
The given solution controls the orientation by the view parameters.
Yet there is a so called Maxima Draw3D region, where interactive rotation is possible, at the price of slightly less stability (the region might freeze).
#5 Publicado: 5/10/2020 16:54:49
You can do it much differently and more profitable:
1. Tabulate a 10 x 10 xy matrix [per say]
2. Install the spline 2D
3. Mesh finer CreateMesh.
4. Orient at will.
5. Plot the 2D oriented.
The bonus is that you can spline/interpolate the original matrix.
#6 Publicado: 6/10/2020 14:38:20
Dariusz Pogocki
Dariusz Pogocki
Hi! Maxima works after instalaton of the last, 64-bit version.
The lectures I have for biology students, which are mathematically impaired (excluding statistics, which they learn but hate). Therefore I would like for them simplest possible solution, with "crude" SMath.
Yours,
Dariusz
#7 Publicado: 6/10/2020 14:43:25
Hi. You can adapt this technique to preserve the orientation in the 3D plot or plot the projection of a 3D surface into a 2D plot, both native SMath plots. The original idea isn't mine, but can't find from who I adapt it.
Plot2DAs3D.sm (27,73 KiB) descargado 1616 vez(es).
Plot2DAs3D.pdf (126,78 KiB) descargado 981 vez(es).
#8 Publicado: 6/10/2020 16:19:39
Hi! Maxima works after installaton of the last, 64-bit version.
Yours,
Dariusz
Then the simplest is in native Smath ... ignoring Maxima.
In the attached: spline(x,y,M) is same as bilinear(x,y,M)
spline(x,y,M) adapted from Valery Ochov [MCD]
Spline Matrix Tutorial RECTANGULAR Surface Plot.sm (22,98 KiB) descargado 1647 vez(es).
SplineRectangularMatrix1 Rotate XYZ.sm (54,8 KiB) descargado 1626 vez(es).
Bilinear [Oterwise metric X, Y Directions].sm (77,31 KiB) descargado 1396 vez(es).
#9 Publicado: 6/10/2020 16:51:15
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
Alvaro,perhaps you got this idea from here
https://en.smath.com/forum/yaf_postst2215_Transferring-three-dimensional-image-on-a-two-dimensional--graph.aspx
Alvaro 6/10/2020 18:05:00
#10 Publicado: 6/10/2020 17:21:17
Hi Fridel. Sure from you, but not from this post, which involve very complicate figures. I remember that I ask from another post (I assume now to you) from where you get that gamma factor for rotate the matrix to plot, because have troubles reconstructing it. In spanish literature spherical coordinates and Euler angles are not always the same than in english, and given that SMath 3D plots are left oriented ... with this two issues I have enough. BTW the idea for multiply with a "point of view" matrix it's great and works for make 3D plots in native SMath 2D plot region, or preserve the orientation in 3D. I remember also another post, guess from Jean, with other matrices expressing very simple rotations with integers as coefficients.
#11 Publicado: 6/10/2020 21:50:41
For 3D plots I am applyingplugin "3D Plot Region (Chart3DLi" it works good except saving formatted plots. Have you got any idea how to resolve the problem.
Considered a bug, reported, never solved ... plugin as is
can't mesh, does not save setting => useless.
Practice the attached.
Page2 Unk.sm (36,64 KiB) descargado 1898 vez(es).
#12 Publicado: 7/10/2020 5:24:19
Found it.
Here: https://en.smath.com/forum/yaf_postst14918_3D-Rotation-Matrix.aspx
and here: https://en.smath.com/forum/yaf_postsm54527_AlgLib-3-1x.aspx#post54527
Fridel Selitsky 7/10/2020 6:23:00
#13 Publicado: 7/10/2020 21:23:31
That gamma factor is the Euler [roll, pitch, yaw] NOT commutative,
otherwise: couldn't pilot aircraft !!!
The MeshPlot(T(u,v),0,2*π,35,0,2*π,35) is CreateMesh(,,,,,,,) since at least SS 5346
The attached is Alvaro document optimized SS 6179
Once optimized, it runs ~ 10 times faster but twice timing than CreateMesh.
There are 4 common rotations:
1. Quaternions,
2. Parametric 'X,Y,Z,t'
3. Euler
4. Composite
If you want those demo sheets: say YES.
Cheers, thanks alvaro ... Jean
Utilities Matrix CreateMesh Code [Alvaro].sm (42,07 KiB) descargado 1422 vez(es).
Alvaro 8/10/2020 12:24:00
