include - include() function allow you to include simple definitions from other documents. - Mensajes
This is on my work computer ... not the one at home.WroteUsing Jean's files in the same directory, I updated to Mike's sheet and compared it to UNI's pdf ... I still have an error in the re-definition of BETA. Using latest SMath and plugins.
BTW, I tried with both files on my desktop and in the "C" drive.
Access to Windows Enviroment Variables would be really nice:
include("%SM_INCLUDE%\fn.sm"
=10
Do you think it's possible?
Thank you
I updated to SMath Version 0.99.6884.
Include() cannot read Sheets saved with this SMath Version. The result looks like include(...)=0.
By examining the files I found the new worksheet tag. And the regions tag moved downwards.
after saving with 0.99.6884:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.99.6884.37264"?>
<worksheet xmlns="http://smath.info/schemas/worksheet/1.0">
<settings dpi="96">
<shortcut>Formelsammlung</shortcut>
<identity>
<id>5f168c43-3307-422f-ab94-2a3c16977117</id>
<revision>775</revision>
</dependencies>
</settings>
<regions type="content">
<region id="0" left="567" top="0" width="104" height="215" color="#000000" bgColor="#ffffff" fontSize="10">
<math>
Maybe that's the reason?
WroteBy examining the files I found the new worksheet tag. And the regions tag moved downwards.
Updated (plugin version changed to 0.2.x.x). Try now.
Old worksheets must be saved in the new format.
WroteI use the latest stable 0.99.6884.
As the plugin is not offered through the plugins dialog, I downloaded the latest file directly and replaced the current one.
But that doesn't work:
The plugin was compiled for a more recent SMath Studio, that's why you can't get it through the extensions manager and why you get the error message (in short the library rely on a different interface than the one available in your version, they can't talk each other)
WroteUpdated. Try now.
Is working, with 0.99.6988
Thanks a lot.
Could you update the plugin for the latest stable, please?
Edit:
I have a more comprehensive sheet, which I include:
now (0.99.6988 with updated include extension) the result of include is shown as usual (98 elements), but they are not accessible:
At first start a few equations were present, but finally I can't get it to work.
I can't even say, if the beta Smath app or if the extension is making troubles.
The old extension 0.2.6982.28030 works correctly, apart from " ".
WroteI have a more comprehensive sheet, which I include:
Show me .log file from the plugin directory.
WroteUpdated. Added support for 0.99.6884.
Here you are:
23.02.2019 14:51:58 [ERROR] Das Objekt des Typs "System.Xml.XmlWhitespace" kann nicht in Typ "System.Xml.XmlElement" umgewandelt werden.
>The object of type ... cannot be converted to ...<
