While loop never ends
While loop never ends - Mensajes
#1 Publicado: 13/3/2020 15:27:06
Yes Man
Yes Man
0 me gusta en 6 mensajes.
Hi everyone, I've got problem with while loop. I have this function with Xstart = 0.2 ; Xfinish = 2 ; deltaX = 0.2 and I need to solve it in smath studio, but while loop is processing forever and never ends. I'm doing something wrong, or it's a bug? Thanks!
Images:
https://postimg.cc/Q9mqWkKd Smath studio
https://postimg.cc/KKZkgXPt Function I need to solve
#2 Publicado: 13/3/2020 16:58:44
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
Is this what you need?
#3 Publicado: 13/3/2020 17:14:41
Yes Man
Yes Man
No, I need a range of numbers for X and Y, like: First X = 0.2, it's calculating Y(0.2) and shows first Y result, then X = 0.4 (previous X + delta X) and it's calculating Y(0.4), and until x = 2. In final I need a range of all X and all Y results.
#4 Publicado: 13/3/2020 17:30:47
Some examples ...
Utilities Pts Critical Monte-Carlo.sm (18,33 KiB) descargado 1242 vez(es).
Utilities Program While FindIndex.sm (34,87 KiB) descargado 1226 vez(es).
#5 Publicado: 13/3/2020 17:55:24
Yes Man
Yes Man
Some examples ...
I'm not sure I understood how to solve my function by this examples.
I don't know what I'm doing wrong:
#6 Publicado: 13/3/2020 20:38:39
Your proposal is not a case of while loop,
strictly wrong application.
Page44 Unknown.sm (73,22 KiB) descargado 1451 vez(es).
#7 Publicado: 14/3/2020 6:06:47
Grupo: Moderator
You can do the job using a while loop but it is just one option (perhaps not the most straightforward one).
loops.sm (10 KiB) descargado 1253 vez(es).
Davide Carpi 14/3/2020 7:20:00, frapuano 14/3/2020 8:38:00, sergio 14/3/2020 14:01:00
#8 Publicado: 14/3/2020 6:19:48
Yes Man
Yes Man
I need all X and all Y(x) values in the end, for Xfirst = 0.2, Xlast = 2 with step 0.2.
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
And it should look something like this:
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
I can type every y(x) in smath studio:
https://postimg.cc/0bddLTqF
But, is it possible to do it with while loop?
#9 Publicado: 14/3/2020 6:21:13
Yes Man
Yes Man
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
#10 Publicado: 14/3/2020 8:25:47
What you are asking for is so restricted and useless for purpose !
Then you can:
1. start wherever [L] as long as computable your ln(,)
2. end wherever [N]
3. as fine step size [Δ]
4. algo style for infinite applications
#11 Publicado: 14/3/2020 8:52:29
Yes Man
Yes Man
Then you can:
2. end wherever [N]
I'm asking for this cos' we are learning Pascal programming language in university, and we need to write this function in Pascal with [while a<=b do], and check it in MathCAD or SMath studio program.
I don't need any graphics, I just need to check the function with while loop. You sent example without while loop and without Xlast = 2, so is it possible to check this function with while loop, or no?
#12 Publicado: 14/3/2020 10:11:42
Pascal is pretty retarded these days for Engineering applications !
Years ago, Mathcad for Universities was pretty freaked.
Better use Smath productive for studies & Engineering.
Golden ratio will be a life time productive Companion.
As well as an advanced WhileLoop.
Golden Ratio jmG.sm (39,41 KiB) descargado 1219 vez(es).
#13 Publicado: 14/3/2020 11:20:50
Grupo: Moderator
Absolutely, and there are several ways.
If you need a step-by step feedback on the fly you can use breakpoints (menu of math regions) and the debugger window ("View" menu). You might have to store the intermediate results in a dedicated variable though, to don't look into the whole matrix at each step.
Also you can use the function trace() and the output window, or you can build math strings using concat() and other functions, or maybe something more complex using the script region plugin by uni.
loops-1.sm (30,01 KiB) descargado 1160 vez(es).
sergio 14/3/2020 14:35:00, frapuano 14/3/2020 16:00:00, SteelCat 17/5/2020 15:51:00
