Mathcad Toolbox - Contains analogs of functions from Mathcad - Mensajes
DraghilevSolveBlock.sm (549,05 KiB) descargado 1871 vez(es).
DraghilevSolveBlock.pdf (1,42 MiB) descargado 1204 vez(es).
WroteBTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
I haven't done this yet because I want the user to be able to choose the type of lines. For all sides.
WroteUnfortunately, I can't reproduce your parametric plot example.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
Links:
1. Added support for parametric plot type
WroteAmazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know.
It's funny, I haven't tried it. I want to simplify the input of text programs. This is another way to extend the functionality of the program through third-party libraries.
A lot of useful libraries have been developed now. There is no point in repeating all this. It is necessary to create flexible interfaces for their integration and interaction with each other.
Wrote... I want to simplify the input of text programs. ...
Yep. It would be very practical to have a tool to capture text to process it. I try to use description() function, but it has the drawback that it must be called at the worksheet level and it doesn't work well within the body of a function. Like in chess, RPN, Code or XYOptions.
Plugin updated.
Changes:
- MathcadBlock: added support for TextRegion.
maple-system-python-TextRegion.sm (5,58 KiB) descargado 1683 vez(es).
Plugin updated.
Changes:
- MathcadBlock: added support for function definition.
Now the function definition can be written directly in the block.
maple-system-execute.sm (8,08 KiB) descargado 1756 vez(es).
Memo Region also supported but it has not been updated for a long time, so some of its text functions do not work.
7-1.sm (29,01 KiB) descargado 1725 vez(es).
WroteIs there a chance to at least partially use units here?
This is an option for having partial and full units support.
7-1-units.sm (35,56 KiB) descargado 1697 vez(es).
By whatever reason, the unit of the independent variable is respected in rkfixed()=even though it is set to 1 locally. Whatever locally means if that happens in the last input parameter value.
7-1_units.sm (39,68 KiB) descargado 1726 vez(es).
dint - Rkadapt bug.sm (24,83 KiB) descargado 1758 vez(es).
dint-RK.sm (49,38 KiB) descargado 1767 vez(es).
dint-RK.pdf (197,5 KiB) descargado 1274 vez(es).
WroteОн должен загрузиться автоматически при выборе из галереи дополнений, либо при открытии любого документа, использующего плагин. Возможно это временные неполадки на сервере.
В том и дело, что и скачать на сайте не получается, и при открытии установка плагина завершается ошибкой.
