Snapshot Region - Extends SMath Studio with a region that makes canvas' snapshots - Mensajes
WroteI can do it, but are you sure? if you want just to resize the region and you go outside the placeholders, the region will resize (just to ask, I agree with the "less things as possible" approach)...
OK, then how about double-click?
If you can resize by mouse action all over the region, why do you need the placeholders? Resizing just by dragging any point inside would be easier than to point at the tiny markers...
BTW, if the image is displayed using an image region (by uni), then the image export is silently blocked for the rest of the session, even if the image region is removed afterwards. This might as well happen if other software has the images open. Thus I would recommend to issue an error message if export fails (if that can be checked).
WroteBtw export reports are available in the bottom left corner of smath
Cool.
BTW: The region is not Ctrl-drag-proof.
WroteBTW: The region is not Ctrl-drag-proof.
What's the issue with ctrl+drag?
http://screencast-o-matic.com/watch/cIQTrhVm8V
mhhh... Isn't the same behavior of other regions?Wrotedone see the post above
Found & Fixed, thank youWroteSorry for being unspecific, see attachment. To relieve you have to press continue and then ESC to drop the copy operation.
@kilele: your video shows, that you are writing a snapshot doc as well, is that right? If so, how about a bit of co-ordination? I really do not insist on documenting everything myself and would be happy to integrate contributions to the activebook (can be done via SVN). There is plenty of white spots, a lot of work yet to do...
Plugin Snapshot Region.sm (45,04 KiB) descargado 1655 vez(es).
WroteHandbook page for Snapshot region added.
Is my plugin reference's sheet, I'll send you a link
WroteI'd propose to write the export files with white background instead of translucent. Perhaps this might be an option. The problem shown in the attached image could also be solved by the image region providing white background. But that would not be entirely equivalent, because the Image region is currently unaware of the image dimensions.
That's an image region feature, the exported PNGs are not transparents (try yourself opening the images with an image editor)
- version 1.0.* (password is no more required);
- Double-click over the region to make the region compact/fullsize;
- Added Spanish translations (thanks to kilele);
- Fixed Italian and German translations (thanks to Martin Kraska);
- Fixed crashes due to wrong handling of exceptions' propagations;
- minor changes.
- SMath Studio 0.96.5146 required
- German translation updated with latest strings
best regards,
Davide
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely)
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.OutOfMemoryException: Nicht genügend Arbeitsspeicher.
bei System.Drawing.Bitmap.Clone(RectangleF rect, PixelFormat format)
bei SnapshotRegion.Implementer.ExportSnapshots(MenuButtonArgs args, ExportSet flag)
bei ..(Object , RegionBase , MenuButton )
bei ...(Object , EventArgs )
bei System.Windows.Forms.MenuItem.OnClick(EventArgs e)
bei System.Windows.Forms.Command.Invoke()
bei System.Windows.Forms.Control.WmCommand(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 2.0.0.0.
Win32-Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll.
SMathStudio_Desktop
Assembly-Version: 0.97.5154.6566.
Win32-Version: 1.1.27.0.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMathStudio_Desktop.exe.
Win32-Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
Win32-Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
ioman
Assembly-Version: 0.97.5154.6193.
Win32-Version: 0.97.5154.6193.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/ioman.DLL.
System.Windows.Forms.resources
Win32-Version: 2.0.50727.5420 (Win7SP1.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
canvas
Assembly-Version: 0.97.5154.6194.
Win32-Version: 0.97.5154.6194.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/canvas.DLL.
rview
Assembly-Version: 0.97.5154.6223.
Win32-Version: 0.97.5154.6223.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/rview.DLL.
System.Xml
Win32-Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400).
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll.
MathcadFileAccess
Assembly-Version: 1.0.5036.4937.
Win32-Version: 1.0.5036.4937.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/02a1c2c5-590e-46bb-bcf6-c87856a8b14b/1.0.5036.4937/MathcadFileAccess.dll.
NuLib
Assembly-Version: 1.64.5154.6194.
Win32-Version: 1.64.5154.6194.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/NuLib.DLL.
SliderRegion
Assembly-Version: 0.1.5177.6941.
Win32-Version: 0.1.5177.6941.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/0c864749-6fe8-4f62-a74d-f6ac601e52a5/0.1.5177.6941/SliderRegion.dll.
CustomFunctions
Assembly-Version: 1.0.5177.39372.
Win32-Version: 1.0.5177.39372.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.0.5177.39372/CustomFunctions.dll.
FIRFilterDesign
Assembly-Version: 1.0.4972.7542.
Win32-Version: 1.0.4972.7542.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/191f7c7a-6b6e-4af0-8bb7-c7a202d59cd4/1.0.4972.7542/FIRFilterDesign.dll.
3DPlotRegion
Assembly-Version: 0.1.5161.27307.
Win32-Version: 0.1.5161.27307.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/2427d808-1e5e-4ae0-88bf-bc271664a3ab/0.1.5161.27307/3DPlotRegion.dll.
System.Design
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll.
FunctionsExtension
Assembly-Version: 0.0.5093.5251.
Win32-Version: 0.0.5093.5251.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/0.0.5093.5251/FunctionsExtension.dll.
ComboBoxRegion
Assembly-Version: 0.1.5146.31497.
Win32-Version: 0.1.5146.31497.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/28ea70bd-1dee-4200-b2e1-1d53d5832487/0.1.5146.31497/ComboBoxRegion.dll.
SMathFinancials
Assembly-Version: 1.0.4928.30282.
Win32-Version: 1.0.4928.30282.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/36acfa39-f2ec-4733-9b68-6f96426f672a/1.0.4928.30282/SMathFinancials.dll.
NumericUpDownRegion
Assembly-Version: 0.1.5171.2523.
Win32-Version: 0.1.5171.2523.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/43438e49-5428-4036-8991-ce03b1d1e572/0.1.5171.2523/NumericUpDownRegion.dll.
MaximaPlugin
Assembly-Version: 1.97.5154.32221.
Win32-Version: 1.0.0.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.97.5154.32221/MaximaPlugin.dll.
HyperlinkRegion
Assembly-Version: 1.0.5177.32144.
Win32-Version: 1.0.5177.32144.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.5177.32144/HyperlinkRegion.dll.
MatlabCppMathLibrary
Assembly-Version: 1.0.4987.26944.
Win32-Version: 1.0.4987.26944.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/4c2faab1-4d93-4904-8d88-a4e21512d179/1.0.4987.26944/MatlabCppMathLibrary.dll.
TableRegion
Assembly-Version: 0.1.5162.30215.
Win32-Version: 0.1.5162.30215.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/51fec712-ec75-4551-a13e-478d375ae8d6/0.1.5162.30215/TableRegion.dll.
CurrencyUnits
Assembly-Version: 0.1.5117.2578.
Win32-Version: 0.1.5117.2578.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dbac4cd-5f31-4a17-982e-f3233b0546de/0.1.5117.2578/CurrencyUnits.dll.
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
mscorlib.resources
DataExchange
Assembly-Version: 1.0.5172.2758.
Win32-Version: 1.0.5172.2758.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/DataExchange.dll.
Ionic.Zip
Assembly-Version: 1.9.1.8.
Win32-Version: 1.9.1.8.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.0.5172.2758/Ionic.Zip.dll.
NonlinearSolvers
Assembly-Version: 1.0.9999.5.
Win32-Version: 1.0.9999.5.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/618b7e96-330a-406a-b055-9e577672f0b8/1.0.9999.5/NonlinearSolvers.dll.
ClosedXML
Assembly-Version: 0.68.1.0.
Win32-Version: 0.68.1.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/ClosedXML.dll.
DocumentFormat.OpenXml
Assembly-Version: 2.0.5022.0.
Win32-Version: 2.0.5022.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/DocumentFormat.OpenXml.DLL.
System.Core
Assembly-Version: 3.5.0.0.
Win32-Version: 3.5.30729.5420 built by: Win7SP1.
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll.
WindowsBase
Assembly-Version: 3.0.0.0.
Win32-Version: 3.0.6920.5453 built by: Win7SP1GDR.
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll.
XlsxImportExport
Assembly-Version: 1.0.4909.14933.
Win32-Version: 1.0.4909.14933.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/621b8a62-bd79-47fc-948b-d4c4ab3b8588/1.0.4909.14933/XlsxImportExport.dll.
ImageRegion
Assembly-Version: 1.0.5149.39321.
Win32-Version: 1.0.5149.39321.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/ImageRegion.dll.
SharpVectors.Core
Assembly-Version: 0.3.1.1588.
Win32-Version: 0.3.1.1588.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Core.dll.
SharpVectors.Css
Assembly-Version: 0.3.1.1590.
Win32-Version: 0.3.1.1590.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Css.dll.
SharpVectors.Dom
Assembly-Version: 0.3.1.1589.
Win32-Version: 0.3.1.1589.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Dom.DLL.
SharpVectors.Model
Assembly-Version: 0.3.1.1592.
Win32-Version: 0.3.1.1592.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Model.dll.
SharpVectors.Rendering.Gdi
Assembly-Version: 0.3.1.1595.
Win32-Version: 0.3.1.1595.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/63ddaef8-9a56-4ff6-938e-d590b638bf99/1.0.5149.39321/SharpVectors.Rendering.Gdi.dll.
StatisticalTools
Assembly-Version: 1.0.4902.38391.
Win32-Version: 1.0.4902.38391.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/76f6e9f5-ac86-4ffb-9e4d-284c8daecaf9/1.0.4902.38391/StatisticalTools.dll.
ExcelFileType
Assembly-Version: 1.3.5031.1884.
Win32-Version: 1.3.5031.1884.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ExcelFileType.dll.
ICSharpCode.SharpZipLib
Assembly-Version: 0.86.0.518.
Win32-Version: 0.86.0.518.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/ICSharpCode.SharpZipLib.dll.
NPOI
Assembly-Version: 2.0.1.0.
Win32-Version: 2.0.1.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.dll.
NPOI.OOXML
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OOXML.dll.
NPOI.OpenXmlFormats
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXmlFormats.DLL.
NPOI.OpenXml4Net
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/7b0c4cfe-fe73-47f1-a4f8-6b3ebcd094e8/1.3.5031.1884/NPOI.OpenXml4Net.dll.
AlgLib
Assembly-Version: 1.0.4972.7412.
Win32-Version: 1.0.4972.7412.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/8e40b49c-3681-4332-903d-751303860e7b/1.0.4972.7412/AlgLib.dll.
SnapshotRegion
Assembly-Version: 1.0.5157.476.
Win32-Version: 1.0.5157.476.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/9166ba14-4cd9-47f6-b988-e96526b16cc9/1.0.5157.476/SnapshotRegion.dll.
mcadefi
Assembly-Version: 1.0.4977.35617.
Win32-Version: 1.0.4977.35617.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/91a20d24-c30b-4774-9b1b-4d502a80420f/1.0.4977.35617/mcadefi.dll.
CFLabelRegion
Assembly-Version: 1.0.5157.770.
Win32-Version: 1.0.5157.770.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/a43ac8f9-29d7-4e8a-9ad0-82cf7c4e14f6/1.0.5157.770/CFLabelRegion.dll.
TextRegionUtilities
Assembly-Version: 0.1.5176.21422.
Win32-Version: 0.1.5176.21422.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/a9f5e37d-83f5-4a4b-a106-0ba7b202abbb/0.1.5176.21422/TextRegionUtilities.dll.
PdfFileType
Assembly-Version: 1.0.5146.31046.
Win32-Version: 1.0.5146.31046.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfFileType.dll.
PdfSharp
Assembly-Version: 1.32.2608.0.
Win32-Version: 1.32.2608.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.5146.31046/PdfSharp.dll.
CheckBoxRegion
Assembly-Version: 1.0.5146.31372.
Win32-Version: 1.0.5146.31372.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/aeb799ab-3afc-4a82-8f44-27d03df672ca/1.0.5146.31372/CheckBoxRegion.dll.
XYPlotRegion
Assembly-Version: 0.1.5151.38078.
Win32-Version: 0.1.5151.38078.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/c12231ec-4873-43c1-a7d0-a167ebd17066/0.1.5151.38078/XYPlotRegion.dll.
ModellerRegion
Assembly-Version: 1.0.5147.447.
Win32-Version: 1.0.5147.447.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/ModellerRegion.dll.
netDxf
Assembly-Version: 0.1.2.0.
Win32-Version: 0.1.2.0.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/d5139464-68f1-4c95-bb0a-66f7ac41f86c/1.0.5147.447/netDxf.dll.
GPCWrapper
Assembly-Version: 1.0.4914.35302.
Win32-Version: 1.0.4914.35302.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f01/1.0.4914.35302/GPCWrapper.dll.
iode64
Assembly-Version: 1.0.4975.7445.
Win32-Version: .
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/iode.dll.
ODESolvers
Assembly-Version: 1.0.4975.7557.
Win32-Version: 1.0.4975.7557.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/ddc09821-49f1-4c21-a829-6499de0a8f06/1.0.4975.7557/ODESolvers.dll.
msvcm90
Assembly-Version: 9.0.30729.6161.
Win32-Version: 9.00.30729.6161.
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll.
include
Assembly-Version: 1.0.5082.41871.
Win32-Version: 1.0.5082.41871.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/dfdcd1f7-5005-45f1-8bf8-016fb072ccf3/1.0.5082.41871/include.dll.
DevelopmentTools
Assembly-Version: 0.1.5156.42223.
Win32-Version: 0.1.5156.42223.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/f406188b-ff0e-4b02-8b05-8d6fda91e357/0.1.5156.42223/DevelopmentTools.dll.
GNUScientificLibrary
Assembly-Version: 1.0.4988.38288.
Win32-Version: 1.0.4988.38288.
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/GNUScientificLibrary.dll.
gsl
Assembly-Version: 1.0.4988.38244.
Win32-Version: .
CodeBase: file:///C:/Users/Kraska/AppData/Roaming/SMath/extensions/plugins/fc3a9073-15c5-4991-b358-5ae635ae62d5/1.0.4988.38288/gsl64.dll.
HTMLFileType
Assembly-Version: 1.13.5154.6538.
Win32-Version: 1.13.5154.6538.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/HTMLFileType.dll.
ImageFileType
Assembly-Version: 1.9.5154.6541.
Win32-Version: 1.9.5154.6541.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ImageFileType.dll.
PictureRegion
Assembly-Version: 1.10.5154.6544.
Win32-Version: 1.10.5154.6544.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PictureRegion.dll.
PlotRegion
Assembly-Version: 1.9.5154.6547.
Win32-Version: 1.9.5154.6547.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PlotRegion.dll.
SMathFileType
Assembly-Version: 1.9.5154.6550.
Win32-Version: 1.9.5154.6550.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SMathFileType.dll.
SpecialFunctions
Assembly-Version: 1.11.5154.6552.
Win32-Version: 1.11.5154.6552.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SpecialFunctions.dll.
TextRegion
Assembly-Version: 1.10.5154.6555.
Win32-Version: 1.10.5154.6555.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/TextRegion.dll.
ViewerFileType
Assembly-Version: 1.1.5154.6559.
Win32-Version: 1.1.5154.6559.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ViewerFileType.dll.
XMCDFileType
Assembly-Version: 1.12.5154.6563.
Win32-Version: 1.12.5154.6563.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/XMCDFileType.dll.
2xwrdnrd
SyLib
Assembly-Version: 1.31.5154.6193.
Win32-Version: 1.31.5154.6193.
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SyLib.DLL.
System.Drawing.resources
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing.resources/2.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
![2013-12-20 01_35_11-SMath Studio Desktop - [Piastra di base [EC3].sm_].png](/es-ES/files/Download/gVeCKn/2013-12-20-01_35_11-SMath-Studio-Desktop---[Piastra-di-base-[EC3].sm_].png)
