"Save as..." errors
"Save as..." errors - error saving as "xmcd" or "html" files - Mensajes
#1 Publicado: 3/2/2021 15:52:59
Jing Xu
Jing Xu
0 me gusta en 2 mensajes.
I created a *.sm file. Everything works well. Then I tried:
1) "Save as..." ".html" file -> error message: "Parameter is not valid"
2) "Save as..." ".xmcd" file -> error message: "Root element is missing"
Anything I should do differently?
#2 Publicado: 4/2/2021 6:15:50
Grupo: Moderator
I cannot reproduce the issue. Any further info about how to reproduce it? (Program version, OS, steps to create the file, etc...)
#3 Publicado: 4/2/2021 12:32:15
Jing Xu
Jing Xu
Thank you for replying. I'm using SMath 0.99 (build: 7691), Windows 10 on PC. I did some experiment. The file was imported from MathCAD originally and I used it as a template. There appears to be a hidden (white) lines in the file. After I managed to select and delete the lines, "Save as..." for both file types worked.
