Vector Variable
Vector Variable - Display a vector variable - Mensajes
#1 Publicado: 4/5/2023 19:45:43
Basile
Basile
8 me gusta en 172 mensajes.
Can I have a variable be displayed as boldface or with an arrow above, to display a vector variable v (scalar) v (vector), or phasor, etc. ?
Thank you,
Basile
#2 Publicado: 4/5/2023 22:14:58
Explore Charmap for more or otherwise.
#3 Publicado: 5/5/2023 10:54:21
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings,
Bold face:
  • Can take advantage of 'Absolute Definitions,' they behave like a variable, but are evaluated an order before a standard variable.
    To use, type the 「~」 character, and then your variable name. You can copy and paste the following:
    ~v:#[/code][/list]
    [u]Arrows 'above':[/u]
    [list][*]If you want an arrow above, you can copy/paste the following:
    [list][*][code=markup]v⃑:#
  • v⃗:#
  • Related forums:
    • https://en.smath.com/forum/yaf_postst23318_Arrows-bei-Vectors.aspx
    • https://en.smath.com/forum/yaf_postst23323_-ready-Vector-arrow.aspx
    [/list]
    May this be of Good Help;
    -Kenny Lemens, P.E. ᵂᴵ
  • "No matter where you go, there you are." -Buckaroo BanzaiHotkeys: https://en.smath.com/forum/resource.ashx?a=45771&b=2
    #4 Publicado: 5/5/2023 22:12:54
    Basile
    Basile
    Hello Kenny,
    1. Is there an easy way to enter the arrow above the letter?
    2. How I can enter a hat (unit vector) above a letter?
    Thanks,
    Basile
    #5 Publicado: 8/5/2023 10:30:33
    Greetings,
    Not that I am aware of; I did write code to accomplish this (reference forum: https://en.smath.com/forum/yaf_postsm79999_SMath-Keyboard-Shortcuts.aspx#post79999), but I didn't deploy it as an plugin.
    As for a native solution, I have a txt file with these special characters that I just copy/paste (apparently copy/paste from a browser isn't reliable for these special characters, hence the standalone txt file):
    SpecialChar_Combine.txt (74 B) descargado 1242 vez(es).
    Another solution is to utilize EnableHexNumpad on your keyboard and enter the hex code manually for these characters (but you could easily download a 3rd party application that allows you to assigns hotkeys to insert these special characters as well.
    See the attached txt file above (or the url link; the keyboard shortcut list will provide you the hex code under Formatting Math Region (top of page 3).
    #6 Publicado: 10/5/2023 10:41:57
    Basile
    Basile
    Thank you, Kenny!
    Basile
