Ideas for further plugins - Ideas and resources about possible plugin improvements - Mensajes
The image region plugin works well for SVGs, thank you.
Unfortunately, when 'saved as' a PDF they are rendered out as rasters (not very good ones).
It could be interesting to implement a plugin that allows me to mark a variable located anywhere on my sheet and monitor its value while I change another variable elsewhere. For example, when designing, approval values are often at the end, while the main input is at the beginning. Every time I need to see how a change affects the variable of interest, I have to scroll all the way down to check it, which makes the process very tedious.
There was also the split-window Mode, once upon a time.
However, another way could be the use of absolute variables (those that have a leading tilde character in the name).
Define ~abs_variable_name:variable_name after your actual calculation, then put the evaluation of ~abs_variable_name wherever is best for you.
Editado 12/2/2026 19:31:59
sergio 12/2/2026 19:50:45
