IAPWS-97 [20210206]
IAPWS-97 [20210206] - IAPWS-97 [20210206] - Mensajes
#1 Publicado: 6/2/2021 12:28:02
Inst_IAPWS region 1 MostUsed.sm (184,78 KiB) descargado 1418 vez(es).
#2 Publicado: 7/2/2021 3:33:32
Laurent Fournier
Laurent Fournier
9 me gusta en 66 mensajes.
Dear Jean,
Impressive as usual, but too steep for my understanding... as usual too!
Are all these water saturation/pressure/enthalpy calculations directly made by you from raw data?
I don't see any of the usual water pressure formulae (Tetens, etc.) in this sheet.
#3 Publicado: 7/2/2021 12:35:29
Dear Jean,
My Bible is mostly the 1958 M.P. WUKALOWITSCH water steam booklet
in 4 languages: French, English, German, Russian.
No significant disagreement wrt IAPWS-97,
all those properties are experimental with some uncertainties.
I also consult Katmar not freeware but can be used 5 min per session 0 $.
I got lot of stuff from Bernard Spang [ChemEng].
Most of the polynomials in this document agree with Lagrange criteria ± sign.
For an unknown reason the Grand Savants have ignored Thiele.
The attached SUPPLEMENT is simply gorgeous as bar saturation.
It borrows the data points from so called source and up to execute.
In a steam circuit, measuring the temperature from pressure is much
faster than via T/C [Thermo-Couple} and more accurate unless a high
quality Pt100 thermometer is used, very fragile and slow.
Thanks Collab for your appreciation ... Jean.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (70,61 KiB) descargado 1415 vez(es).
#4 Publicado: 7/2/2021 14:31:28
... in your document, round 'K' 6 decimals.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (72,02 KiB) descargado 1412 vez(es).
#5 Publicado: 8/2/2021 12:44:22
Dear Jean,
Ioha,
For you curiosity, I have added two Tetens segments [brute force] not to avail.
The Lagrange poly order 9 is lot more accurate as a single function.
Water is like air, their properties don't respond to single DE,
thus the need to best piece wise approximate.
Air between -1 km ... 100 km is in 3 pieces [NASA, OACI]
Page16 Tetens.sm (45,44 KiB) descargado 1516 vez(es).
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (114,48 KiB) descargado 1396 vez(es).
#6 Publicado: 9/2/2021 16:28:51
Dear Jean,
The two documents refreshed/refactored.
1. most used ... Last Lagrange replaced by a normalized rational fraction.
2. ... SUPPLEMENT refactored to extends Tetens [180 °C, 10 bar]
Given both ways saturation [bar(°C), °C(bar)].
If you have more interest in Tetens, I may look to extend a bit more.
Please, let me know. Take care ... Jean.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (152,75 KiB) descargado 1407 vez(es).
Inst_IAPWS region 1 MostUsed.sm (193,49 KiB) descargado 1392 vez(es).
#7 Publicado: 9/2/2021 22:37:43
This last brew certifies/solves Tetens [85.9 bar ... 300 °C].
Enjoy ... Jean
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (161,54 KiB) descargado 1390 vez(es).
#8 Publicado: 10/2/2021 5:17:05
Laurent Fournier
Laurent Fournier
Dear Jean, I am only architect and I used Tetens' formula just to find the absolute humidity from the relative humidity from data collected from my data loggers... Your calculations are far too accurate for my needs!
However I will share my attempts at dome calculations based on Maxwell's polar polyedra and Marina Konstantatou's thesis (I have seen impressive visuals here based on just the in-built 2D and 3D graph regions)... for which you could maybe help me!
Thank you,
Laurent
#9 Publicado: 10/2/2021 9:34:10
However I will share my attempts at dome calculations based on Maxwell's polar polyhedra and Marina Konstantatou's thesis (I have seen impressive visuals here based on just the in-built 2D and 3D graph regions)... for which you could maybe help me!
Thank you,
Laurent
Laurent, please attach some data [vectors, table ...].
I can't resit data ... smoothing, fitting, surface plot, rotation.
Your stuff will delight Smath Community and we all go along so well !
Wait and see from so far away ... Jean
#10 Publicado: 10/2/2021 15:02:47
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
Dear Jean,
Updated my Water Vapor Saturation file. It's per ASHRAE IP units
#11 Publicado: 10/2/2021 17:20:21
... last segment in pink [255, 225, 225] pushes Tetens up to 370 °C ± 0.5 bar.
Inst_IAPWS region 1 MostUsed SUPPLEMENT.sm (167,55 KiB) descargado 1406 vez(es).
