One more about lens
One more about lens - Mensajes
#1 Publicado: 1/12/2024 1:52:00
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (43,8 KiB) descargado 1841 vez(es).
See too
https://en.smath.com/forum/yaf_postst25212_Lens.aspx
#2 Publicado: 1/12/2024 18:08:12
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Valery Ochkov 2/12/2024 15:44:00
#3 Publicado: 1/12/2024 19:52:45
Grupo: Moderator
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
Archivo no encontrado.Archivo no encontrado.
Valery Ochkov 2/12/2024 15:45:00, francesco rapuano 3/12/2024 4:21:00
#4 Publicado: 7/12/2024 13:02:58
Valery Ochkov
Valery Ochkov
Mathcad Prime
#5 Publicado: 8/12/2024 1:05:34
Cornel
Cornel
2 me gusta en 78 mensajes.
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
#6 Publicado: 8/12/2024 1:21:21
Valery Ochkov
Valery Ochkov
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
#7 Publicado: 8/12/2024 2:29:44
Grupo: Moderator
What's wrong with the existing solvers?
#8 Publicado: 8/12/2024 3:54:39
Cornel
Cornel
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
#9 Publicado: 8/12/2024 5:04:39
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (308,62 KiB) descargado 2255 vez(es).
RKA.pdf (931,16 KiB) descargado 1722 vez(es).
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
● [topic=17088]Intel ODE Solver Library[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
#10 Publicado: 8/12/2024 8:58:47
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (179,91 KiB) descargado 1814 vez(es).
I also use the Martin's setup for the plot.
#11 Publicado: 9/12/2024 10:44:48
Valery Ochkov
Valery Ochkov
How to create this picture
https://en.wikipedia.org/wiki/Spherical_aberration
#12 Publicado: 10/12/2024 4:11:05
Hi Valery. This is a way.
spherical aberration.sm (15,88 KiB) descargado 1803 vez(es).
Oscar Campo 10/12/2024 9:43:00, Valery Ochkov 10/12/2024 12:26:00
#13 Publicado: 10/12/2024 12:38:25
Valery Ochkov
Valery Ochkov
Thanks!
The last step
#14 Publicado: 10/12/2024 21:21:41
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (26,41 KiB) descargado 1951 vez(es).
francesco rapuano 10/12/2024 23:05:00, NDTM Amarasekera 10/12/2024 23:16:00, Вячеслав Мезенцев 10/12/2024 23:19:00
#15 Publicado: 10/12/2024 21:35:39
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
Very elegant solution
Alvaro 11/12/2024 6:18:00
#16 Publicado: 11/12/2024 3:06:13
Grupo: Moderator
Root-free version of the spherical lens
spherical aberration_Kr.sm (12,37 KiB) descargado 1735 vez(es).
#17 Publicado: 11/12/2024 6:22:06
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
Oscar Campo 11/12/2024 12:09:00
#18 Publicado: 12/12/2024 4:49:07
Grupo: Moderator
Oscar Campo 12/12/2024 18:29:00, Alvaro 13/12/2024 7:27:00
