Curve fit function?
Curve fit function? - Looking to do a pump curve fit - Mensajes
#1 Publicado: 19/4/2016 12:33:08
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
Could not find an example short of an article by Urroz in 2010 Archivo no encontrado.. He discusses a "LinearDataFit.sm" snippet that I could not find as a download. This sheet Archivo no encontrado. is based off of the data in that PDF file. In Mathcad, I would type "linfit(x,y,F)="
Is there an equivalent?
#2 Publicado: 19/4/2016 14:02:33
CBG
CBG
78 me gusta en 312 mensajes.
Use this example QuadFit.sm (13,64 KiB) descargado 1475 vez(es).
It was taken from here :http://people.stfx.ca/bliengme/SMath/
Add *.sm file of Pump Curve fit: Pump_Fitting_Curve_Example_a.sm (26,14 KiB) descargado 1332 vez(es).
ElSid 19/4/2016 14:10:00
#3 Publicado: 19/4/2016 16:25:10
Use this example QuadFit.sm (44 KiB) descargado 227 vez(es).
Davide Carpi 19/4/2016 19:40:00
#4 Publicado: 19/4/2016 17:13:54
Ruben Sidranski
Ruben Sidranski
CBG's format worked great for me (Thank you). I was going through my MathCAD sheets/notes ...Curve.PNG
#5 Publicado: 19/4/2016 18:12:16
Mike Kaganski
Mike Kaganski
184 me gusta en 434 mensajes.
Just one character fixes Jean's excellent (as usual) sample:
QuadFit (1).sm (40,28 KiB) descargado 1369 vez(es).
С уважением, Михаил Каганский
#6 Publicado: 19/4/2016 18:38:54
"CBG's format worked great for me (Thank you). I was going through my MathCAD sheets/notes ..."
The question is not if CBG works or not in your installation. The problem is
why my work sheet is not compatible to your version. You say it does not work.
Read the error message "Not set to an instance to compute" . So, how many of
the user created function your version won't read ? W/o user programmed functions,
Smath is just a curiosity.
"How simple" from your Mathcad !!! plot and see .
I have same result from OriginLab than Smath. OriginLab was doing gorgeous
fitting much before Mathcad 8/11 , Why? because fitting techniques were developped
between Mathsoft Collabs [especially: Robert, Paul, Jean ...].
"Jean, for the first time, your algo gave me an error".
Yes because your Smath version is not set to read backward version [to be confirmed].
"On a side note, on the picture (very bottom), you define "Poly" at the top of the next graph.
I am olmy familiar with poly and data being on the bottom like the top most picture".
"Poly" is any name to assign the result of the discrete algo.
Cheers, Jean
#7 Publicado: 19/4/2016 19:08:27
Your Mathcad coding is pure invention. It can't be otherwise than
it was Mathcad 8/11. Where does that big blue note comes from ?
#8 Publicado: 19/4/2016 19:17:45
Ruben Sidranski
Ruben Sidranski
Jean,
Your coding is phenomenal. Thank you again. Mike found the "character" that was off. I will look for the whole Mathcad sheet and post. I have snippets all over the place and I promised myself to try and be more organized. Not @ computer, but I think in poly:=, the function needed to be f(_x). I took a quick look see but I did not study
Davide Carpi 19/4/2016 19:21:00
#9 Publicado: 19/4/2016 19:22:53
Grupo: Moderator
Thank you for pointing out where was the issue (and Jean for the code and Mike for the debug too)
In fact is not a problem of SS version, I opened the file attached by Jean with 0.97.5346 and I got the same error.
Still, I see the screenshot of Jean and I don't understand how it is possible that worked for him.
#10 Publicado: 19/4/2016 19:33:59
CBG
CBG
ElSid:
What is the purpose you are looking for adjusting flow ​​against head?
Find a value for a Head with a flow not specified in the flow vector ? , Is it to interpolate ?
If it is to interpolate , the easiest thing is to use directly the function " ainterp (V1 , V2, V3 ) "
A very simple example: Example_Ainterp.sm (6,67 KiB) descargado 1276 vez(es).
#11 Publicado: 19/4/2016 19:53:38
Mike Kaganski
Mike Kaganski
I'm not sure he had x defined above the screenshoted region at the time of screenshoting
Davide Carpi 19/4/2016 19:57:00
#12 Publicado: 19/4/2016 20:00:10
Grupo: Moderator
Good point (it may happens with auto calculation disabled). I think he have to download and evaluate his own attached worksheet and confirm if is still working or not.
#13 Publicado: 19/4/2016 22:08:59
Ruben Sidranski
Ruben Sidranski
I am look at the fixed file from Mike and comparing it to Jean's original file. The only difference I see between them is the underscore in the function f(_x) in the Poly definition. Totally lost with the
  1. Why the underscore made it work?
  2. What the recasting of the scalar does?
#14 Publicado: 19/4/2016 23:11:19
Mike Kaganski
Mike Kaganski
Yes, that's exactly that one character I mentioned above
Citar
  • Why the underscore made it work?
  • Because the "_x" is undefined. Jean used function-as-parameter feature to pass an algo to a function. SMath requires that in this case, the passed function (here it's f(#)) must have its fictive parameters all previously undefined variables. This is very old requirement (I'm unsure if there ever existed a version without it). As Jean has defined "x" above, it coudn't be used as fictive parameter to passed f().
    Edit: wrong English error message is reported as SS-2324.
    #15 Publicado: 19/4/2016 23:40:33
    Hello Collabs ,
    Here is the screen shot of the attached work sheet.
    My installed Smath 5346 is "as is" from the day it was installed.
    No download update. Why the underscore would make it work on Elsid
    version, can't explain. From what you are saying Davide, it looks
    that if some of the "nightly build" reside in the same machine, it
    broke logical link to user define function, or code incompatibility
    between versions.
    Poly Quadratic 5346.sm (38,23 KiB) descargado 1313 vez(es).
    #16 Publicado: 19/4/2016 23:50:43
    Mike Kaganski
    Mike Kaganski
    This topic discusses the functions-as-parameter thing. You may notice, that it's 6 years old (started 24 Jun 2010), much older than 0.97.5346 (21 August 2014). And yet, all requirements, including requirement that all variables must be previously undefined, are already in place.
    And yes, as expected, Jean's last file opens fine, because it doesn't contain global definitions of x.
    #17 Publicado: 20/4/2016 10:26:06
    Ruben Sidranski
    Ruben Sidranski
    Mike,
    Thanks for the explanation
    1. ANSWERED
    The screen shot I posted shows it equals nothing ... Multiplying the vectors with the second one being a vector within a vector does not compute in my brain
    Your Mathcad coding is pure invention. It can't be otherwise than it was Mathcad 8/11. Where does that big blue note comes from ?
    Jean, The Mathcad file I posted in blue does NOT use the same data points, so the polynomial coefficients "b" will be different. I was trying to copy the syntax over to SMath
    Great question. I will post the actual files for a project that describe what I am trying to model as soon as I get a copy of the files from the vendors archive (I cannot find my copies). Essentially, it is a VFD driven pump in a wet well, with a min/max elevation drawdown (range) as the wet well goes up and down so looking at min/max. I want to identify the "trapezoid" that the pump must operate in using the "hatching" code in
    Reservoir Flood Capacity Estimation.sm (188,6 KiB) descargado 1656 vez(es).
    The vendors typically give a "few" data points (some as little as 3). So tying it into one sheet would be phenomenal. Easy to do on paper ...
    I want to use the affinity rules to go from here.
    #18 Publicado: 20/4/2016 11:51:10
    Grupo: Moderator
    The Maxima plugin provides the function Fit(), see the interactive handbook for details.
    Archivo no encontrado.Archivo no encontrado.
    Davide Carpi 20/4/2016 12:35:00
    #19 Publicado: 20/4/2016 12:57:30
    Hello Martin,
    Very interesting, but does not work in 5346.
    Your work sheet does not work either.
    #20 Publicado: 20/4/2016 13:50:13
    Essentially, it is a VFD driven pump in a wet well, with a min/max elevation drawdown (range) as the wet well goes up and down so looking at min/max.I want to identify the "trapezoid" that the pump must operate in using the "hatching" code in
    In 1970 I was working in the mning industries and that problem of min/max didn't exist.
    All our 100's pump box had a little inexpensise level contol. w/o a diagram of what
    you are attempting, hard to visualise. I don't see the relationship with the "Flood"
    work sheet , maybe I'm wrong ? Too many bits and pieces in there.
