How to use the solve function in this task
How to use the solve function in this task - Mensajes
#1 Publicado: 2/6/2024 20:33:38
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
3-2-CoolProp-Solve.sm (46,14 KiB) descargado 1616 vez(es).
#2 Publicado: 2/6/2024 22:24:24
ioan92
ioan92
181 me gusta en 125 mensajes.
Take care :
Your CoolProp function, as you write it, does not change the sign, between the two limits of the variable p :
Valery Ochkov 2/6/2024 23:27:00
#3 Publicado: 2/6/2024 23:27:35
Valery Ochkov
Valery Ochkov
Thanks,
send please the sm-file with the solution
#4 Publicado: 3/6/2024 0:42:55
ioan92
ioan92
The problem, as you formulated, seems as not having a solution in real numbers, in order to be solved with the solve routine.
I'm sorry but I have no time to reformulate your problem.
If you intend to solve it numerically, try to check the continuity of the function and the fact that in the range you look for solution there is at least one change of the function value sign.
Valery Ochkov 3/6/2024 0:59:00
#5 Publicado: 3/6/2024 1:46:02
Grupo: Moderator
The problem as stated in the opening post, actually has a solution in the given range.
Yet, I don't see an alternative to using brute force to tame the coolprop function: sampling and interpolation.
Archivo no encontrado.Archivo no encontrado.
Valery Ochkov 3/6/2024 1:50:00
#6 Publicado: 3/6/2024 2:12:41
Hi. The guess values, in this case the range, are part of the solution, this means that you must know where the numerical procedure works fine. In this case the interval 1 MPa ... 6 MPa.
3-2-CoolProp-Solve.sm (49,75 KiB) descargado 1607 vez(es).
#7 Publicado: 3/6/2024 10:47:51
Valery Ochkov
Valery Ochkov
Thanks, Martin and Alvaro
See please the problem in attach
Fireless-Locomotive.sm (882,15 KiB) descargado 1631 vez(es).
PS
Alvaro!
And what about the book?
#8 Publicado: 3/6/2024 12:58:22
Hi Valery. This could be an option.
Fireless-Locomotive.sm (915,8 KiB) descargado 1631 vez(es).
PS
Alvaro!
I'm pretty busy right now! Sorry.
Valery Ochkov 3/6/2024 16:04:00
#9 Publicado: 3/6/2024 16:29:42
Valery Ochkov
Valery Ochkov
It works! By p.0=240 atm
Fireless-Locomotive.sm (882,15 KiB) descargado 1699 vez(es).
But by p.0=140 atm ---???
Alvaro>
Check please 1-2-3 chapters.
My student from Cuba is waiting for it!
#10 Publicado: 5/6/2024 21:16:15
... Check please 1-2-3 chapters.
Hi Valery. I find it quite inappropriate that what is a voluntary collaboration helping on regarding a translation, and therefore supposedly free of commitment on both sides, is publicly claimed in the forum. This situation seems to reflect some type of irresponsibility on my part as I am failing to make some type of commitment, which, I insist, there is none. I would sincerely like to receive some kind of explanation as to why you are making a public complaint about a translation job on my part when there is no agreed commitment.
#11 Publicado: 5/6/2024 23:25:56
Valery Ochkov
Valery Ochkov
Please forgive me, of course I'm wrong.
Val
#12 Publicado: 6/6/2024 0:18:58
Of course. He is already forgotten.
