1 páginas (7 elementos)
Animation Compendium - Animation Compendium - Mensajes
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (8,86 KiB) descargado 1553 vez(es).
0Anim Analemma.sm (28,67 KiB) descargado 1434 vez(es).
0Anim Ellipse.sm (13,42 KiB) descargado 1474 vez(es).
0Anim Cheval.sm (21,13 KiB) descargado 1508 vez(es).
0Anim Gozilla.sm (11,26 KiB) descargado 1448 vez(es).
0Anim XFR.sm (11,65 KiB) descargado 1488 vez(es).
Enjoy your vist.
Davide Carpi 22/8/2016 12:05:00
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (13,23 KiB) descargado 1441 vez(es).
Davide Carpi 22/8/2016 12:04:00
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (18,42 KiB) descargado 1472 vez(es).
Cheers, Jean
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (30,72 KiB) descargado 1514 vez(es).
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
- 0Anim Analemma.sm (28,88 KiB) descargado 1455 vez(es).
- 0Anim Brownian.sm (8,86 KiB) descargado 1463 vez(es).
- 0Anim Cheval.sm (22 KiB) descargado 1472 vez(es).
- 0Anim Ellipse.sm (13,85 KiB) descargado 1526 vez(es).
- 0Anim Gozilla.sm (11,71 KiB) descargado 1448 vez(es).
- 0Anim XFR.sm (12,01 KiB) descargado 1441 vez(es).
- 0Anim XFR1.sm (11,53 KiB) descargado 1463 vez(es).
- 0Anim CONVOLUTION.sm (28,13 KiB) descargado 1485 vez(es).
Thanks Andrey: I toke good note and adapted.
