Angles trygonometry value in solutions of the system of equations
Angles trygonometry value in solutions of the system of equations - Mensajes
#1 Publicado: 9/9/2021 4:25:42
Mateusz
Mateusz
0 me gusta en 8 mensajes.
How to turn of the decimal values in trygonometry angles value? I got sth lik this for solution of system of equations:
The file with example: example_v1.sm (8 KiB) descargado 1182 vez(es).
A.
#2 Publicado: 9/9/2021 6:44:19
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
You can use the function al_nlegsolve with any initial
assumptions (because the equations are linear)
al_nlegsolve.sm (11,18 KiB) descargado 1184 vez(es).
#3 Publicado: 9/9/2021 9:52:40
How to turn of the decimal values in trigonometry angles value ?
By default, trig are in decimal radian in all CAS.
Recast your solutions, fill-in the unit place holder.
#4 Publicado: 9/9/2021 23:20:45
Hi. You also can use Maxima commands, in this case ev():
#5 Publicado: 10/9/2021 5:37:18
Grupo: Moderator
example_v1.sm (13,63 KiB) descargado 1200 vez(es).
sergio 10/9/2021 6:11:00
#6 Publicado: 10/9/2021 13:02:39
Hi Martin. I use Maxima's ev() because SMath's Assign() only works with the variable names, instead others, like xo, yo, and SMath's at() doesn't works for the symbolic evaluation, as shown this picture:
example_v1.sm (15,95 KiB) descargado 1180 vez(es).
This is a workaround for use only SMath native functions or plugins, without any explicit Maxima function:
example_v2.sm (15,16 KiB) descargado 1250 vez(es).
sergio 10/9/2021 13:43:00
