1 páginas (6 elementos)
design decision - comparing results - Mensajes
Looking for a little guidance..
I'm an engineer, and use Smath in structural design.
In doing so I often need to compare a calculated capacity to a design load.
Can anyone suggest an elegant method of reporting a "result", being: pass or: fail……?
thanks,
Stu.
thanks,
Stu.
One way is to use the conditionally formatted labels extension.
http://en.smath.info/forum/yaf_postst2100_Conditionally-Formatted-Labels.aspx
Another is to present your results in table form using the table region.
http://en.smath.info/forum/yaf_postst1953_Table-Region.aspx
I use most of the time a very simple "if" condition.
No need for plug-ins and very easy to check for any reader.
By using indices you can also create a "table" with all "OK" an "FALSE" results. This can be convenient if you have different load cases with each one or more checks in a large document.
See the attached image.
Hope it is usefull for you!
Regards, csb.
Regards, csb.
I am in agreement with CSB.
You can define a simple function to be used as needed
[albumimg]1420[/albumimg]
Interesting: that reminds me to instruct Smath about a "Truth table", like Mathcad.
