create a function from values
create a function from values - i have a table of values with the corresponding time and need a function i can differentiate - Mensajes
#1 Publicado: 27/11/2019 18:04:57
deleiman
deleiman
0 me gusta en 4 mensajes.
hi i have a table of values [R(t=60)=50965] with no obvious pattern and i need to create a function to fit into the formula
1/T = d (ln(R(t)) / dt
my thought was to make S(t)=ln(R(t)) and do d(S(t))/dt but i dont know how to turn a bunch of values into a function in smath and excel doesnt understand the function properly (i left out the last value and did auto complete and it was too far off)
R(t) is in counts per second
and i am solving for T
#2 Publicado: 27/11/2019 18:30:00
deleiman
deleiman
Start by creating the Smath data table, attach in the Forum.
Your wording looks very alike fitting the laser project.
Toke > 1 month to do in Mathcad as it was so unusual.
But we had lot more data points.
HW8Q1.sm (2,45 KiB) descargado 1162 vez(es).
do you mean like a matrix?
#3 Publicado: 27/11/2019 19:01:34
Before going ahead, the wiggling around the straight fit,
is it real or digitizing noise from equipment ?
#4 Publicado: 27/11/2019 19:08:22
Data.sm (28,76 KiB) descargado 1151 vez(es).
#5 Publicado: 27/11/2019 19:08:35
deleiman
deleiman
i would be comfortable assuming it is based on the contextArchivo no encontrado.Archivo no encontrado.
#6 Publicado: 27/11/2019 21:14:47
... in your original scale XY.
Data.sm (40,67 KiB) descargado 1150 vez(es).
#7 Publicado: 27/11/2019 22:14:46
deleiman
deleiman
thank you so much
as much as i would like to say part b of the question i need to do my own homework i just couldnt understand how to get the equation of that line
thanks again
#8 Publicado: 28/11/2019 0:03:25
thank you so much
as much as I would like to say part b of the question I need to do my own homework I just couldn't understand how to get the equation of that line
1. You mean equation of the straight red line of the first plot ?
2. Or: the piece wise linterp between the support points ?
linterp, cinterp, ainterp are built-in Smath from f(x) menu.
The straight line in [1] can be manipulated a bit from statistical methods [Not Smath built-in].
Also, if you don't like the rough bifurcation at the supports
points, easy to fillet for smooth path.
No more need for the first replies before the last attachment,
then will be removed.
#9 Publicado: 28/11/2019 1:35:47
CBG
CBG
78 me gusta en 312 mensajes.
I think you can also use the least-squares method to find the equation that best fits your data.
Ajust_by_Last_Square_Selection_Engineering_studente.sm (62,08 KiB) descargado 1234 vez(es).
Carlos
sergio 28/11/2019 6:00:00
#10 Publicado: 28/11/2019 8:55:51
Here is Cholesky [Least Squares], otherwise.
Ge sensor [Germanium] is an exceptional application.
Genfit 0 Ge SubCryogenic.sm (39,2 KiB) descargado 1098 vez(es).
Data.sm (54,7 KiB) descargado 1176 vez(es).
