Release Manager Spice# publish error - Mensajes
Checking...
The reason is that the file of the plug-in is 35.5 MB which is the largest plugin right now. Server does not accept such amount of bytes because of security reasons.
Current maximum request limit is 30,000,000 bytes, which is approximately 28.6 MB.
I'm checking what can be done here...
WroteIssue is troubleshot.
Possibly the same issue with ImageEditRegion?
WroteWroteIssue is troubleshot.
Yep, it is 30.2MB, while we are accepting not more than 28.6MB.
It will be fixed, but because of our development cycle (i.e. "temporary everything is broken" but for the good reason!) it may take up to a week...
I will let you know as soon as it is finally handled.
WroteCurrent maximum request limit is 30,000,000 bytes, which is approximately 28.6 MB.
Let's pack it
https://en.smath.com/forum/yaf_postsm86157_SpiceSharp.aspx#post86157
There were many changes done to the plugins related infrastructure and I think most issues must be fixed now, including corrected GUIDs detection and large plugins packages support (up to 50MB ).
We have one more known issue: SMath Studio can't install plugin package if such package contains folders. This requires new version of the program, so it will be fixed in the next release.
Please try to build and upload plug-ins and let me know if any issues remains. I will handle them.
I also want to inform that we are preparing articles which will describe a new way how we recommend developing plugins, but those of you who interested in what is changed may already check this updated plugin: https://smath.com/svn/public/plugins/CheckBoxRegion - main changes are:
- Updated project file (Microsoft.NET.Sdk);
- Using SMathStudio.Core.Ref Nuget package (see full list);
- Released latest API documentation: https://smath.com/documentation/api/SMathStudio.Core/1.73.9126.
I will inform separately when articles will be ready.
Best regards, Andrey Ivashov.
Thank you!
If you click on the Download full log link at the bottom you'll see the following error:
"error NETSDK1050: The version of Microsoft.NET.Sdk used by this project is insufficient to support references to libraries targeting .NET Standard 1.5 or higher. Please install version 2.0 or higher of the .NET Core SDK."
Will try to install latest .Net SDK.
WroteIf you click on the Download full log link at the bottom you'll see the following error:
As I wrote earlier, this log has not been displayed for me for many years. When I try to download it, I get an error: File not found.
WroteWroteIf you click on the Download full log link at the bottom you'll see the following error:
Sorry, forgot about it.
Building a plugin fixed, but as I see an output package contains folders like cs, de, es, fr, it etc... - this will break plugin installation. This is known issue but requires new SMath Studio build.
The best solution for now is to exclude these folders from output (they must be a part of third-party Nuget I think).
WroteThe best solution for now is to exclude these folders from output (they must be a part of third-party Nuget I think).
I'm not sure I can control this. These resources appear automatically. I don't remember which settings are responsible for this, but they are still not available to me. I can insert dependent packages in the sources instead of packages, but it's too complicated.
Spice# plugin can be built, uploaded and installed now.
To make things easier I've converted project to a new style and hope you like it.
Please try.
WroteDone.
Please try.
Yes, now everything works and I can expand the functionality of the plugin. Thank you.
The plugin is now available in the gallery.
