Snippet Operations with units Fail
Snippet Operations with units Fail - Fails on some occasions to detect the units - Mensajes
#1 Publicado: 16/5/2022 19:05:41
CBG
CBG
78 me gusta en 312 mensajes.
Hello
The unit operation snippet fails to detect units.
Snippet_Units_Fail.sm (33,04 KiB) descargado 1654 vez(es).
Carlos
#2 Publicado: 17/5/2022 9:02:34
Grupo: Moderator
Try this
Snippet_Units_Fail.sm (32,38 KiB) descargado 1574 vez(es).
#3 Publicado: 17/5/2022 9:12:04
Hola Carlos ... Jean...OK SS 6179
#4 Publicado: 17/5/2022 16:51:34
CBG
CBG
Hello David
Citar
Try this
Thank you very much for your answer, but the snippet fails, since instead
of finding the units, it only obtains the value of 1
Hola Jean
Saludos
Carlos
#5 Publicado: 18/5/2022 4:44:35
Grupo: Moderator
Hello David
My bad, IDK why but yesterday seemed to work to me, but in fact it doesn't. I'll give another look at the snippet ASAP.
#6 Publicado: 18/5/2022 14:00:44
Grupo: Moderator
I see the issue. The function look for a numerator/denominator pattern in the num2str() text, but doesn't handle cases in which multiple divisions are involved.
#7 Publicado: 18/5/2022 22:47:59
CBG
CBG
Hello David
Thank you very much for your attention, I hope the Snippet has a fix-
On the other hand, I ran the snippet in version 6179,
and it works perfectly. How is that possible?
Carlos
#8 Publicado: 19/5/2022 8:28:50
Grupo: Moderator
I'm not sure, however if you need a urgent fix here you have an easy way to make it working the same way.
