Problem with length() command
Problem with length() command - Mensajes
#1 Publicado: 28/5/2012 4:34:39
ska109
ska109
0 me gusta en 2 mensajes.
Hi, I have a problem using length() commang.
If used on matrix, it works well, but using the length() command on scalar value (which is, I think, matrix of size 1 by 1), it doesn't work well.
length problem
File with this problem: length_problem.sm.
#2 Publicado: 28/5/2012 5:01:40
Grupo: Moderator
You get the last math region [MATH=eng]lx_1=length(-1)[/MATH]. If yoo would use numerical equal to, there would be an error issued.
And, no - scalar is not a matrix of size 1 by 1.
Rdaovan
#3 Publicado: 17/6/2012 7:31:07
ska109
ska109
thank you for your reply. Is trere any other way (instead of using "length()" command) how to find out the number of solutions of the equation?
Thank you for amazing SMath,
kind regards
Jan Skapa
Rdaovan
#4 Publicado: 17/6/2012 7:48:35
Grupo: Moderator
Could you be more specific, please?
#5 Publicado: 17/6/2012 8:46:45
Grupo: Moderator
I don't see your file therefore I'm not sure, but I think that this snippet can help you:
varManager.zip
EDIT(1): now i can see your file
use it in this way:
[MATH]x_1:ToArray(x_1)[/MATH]
EDIT(2): instead of [MATH]x_1:ToArray(x_1)[/MATH] you can use [MATH]x_1:stack(x_1)[/MATH]
(x_1 can be an array, a scalar or a text)
then you can use:
[MATH]length(x_1)[/MATH]
regards,
w3b5urf3r
