1 páginas (4 elementos)
help in results - wrong answer calculated - Mensajes
Hi. Hope that this helps:
As I know, the speed of the sound into a fluid is sqrt(K/rho)=14.9245 ft/sec, for your data and where K is the fluid bulk modulus and rho the fluid density. With your rho, in lbm/ft^3, this is the fluid density. You need g only if you have the specific weight gamma = rho/g. I know that a lot of books use rho for both: density and specific weight, and it's very confusing that notation.
WroteI am having problems with a specific calculation
You are asking the volunteers to remake the document.
On the other hand, working with fluids, the source information(s) is required.
