SOE findroot question: is there an order for vars?
SOE findroot question: is there an order for vars? - different vars order, same result value - Mensajes
#1 Publicado: 11/5/2022 0:02:05
John
John
0 me gusta en 12 mensajes.
Hi, Guys:
I'm using FindRoot for SOE solution,but something make me confusion. for example:
the same SOE with different variables, different result, and the second is wrong.
I think maybe I have something wrong. please help me, how to use the FindRoot?
Thanks a lot!
John
attach the file
soe.sm (6,68 KiB) descargado 1183 vez(es).
#2 Publicado: 11/5/2022 0:24:23
Hi. You must to sort the variables in the same order than Unknowns.
sergio 11/5/2022 4:02:00
#3 Publicado: 11/5/2022 1:49:05
John
John
Hi, is there any rules for the order?
Thanks alot
John
#4 Publicado: 11/5/2022 3:32:40
Hi. You can't redefine Unknowns. Well, you can, but isn't the best idea. Unknowns is a function in the same plugin than FindRoots, SpecialSolvers. I don't know the internals of the plugin. My guess that the general rule is sort the variable names in lexical order, but if the name has unicode characters or some unusual ASCII character, it is best to make sure of the order to follow by evaluating Unknows(eq).
#5 Publicado: 11/5/2022 5:30:29
John
John
okay, I got it. but a new question, why I can't got the result as your picture?
would you mind post the sample sm file ?
Thanks a lot!
John
#6 Publicado: 11/5/2022 6:22:01
SMath have two "=": Numerical and Symbolical. With numerical evaluation you can only obtain numerical values, that is, without undefined variables. Rigth click to change it to symbolic equals, or use Ctrl+period instead "=", or click symbolic evaluation in the right panel.
Sorry, I forgot to post it, and right now can't.
#7 Publicado: 11/5/2022 6:36:21
John
John
thank you!
I got it.
Thanks a lot!
John
#8 Publicado: 11/5/2022 8:31:04
OBSERVE ... so much from so little
Solve Algebraic, NON-Algebraic Read first.sm (69,81 KiB) descargado 1269 vez(es).
#9 Publicado: 11/5/2022 8:56:57
This multi solve companion is 3 x 3
Make it 2 x 2 ... n x n ... as per your project.
Solve Algebraic, MULTISOLVE Companions.sm (17,86 KiB) descargado 1294 vez(es).
#10 Publicado: 11/5/2022 15:32:03
Grupo: Moderator
You can automate assigning guesses to unknowns.
By this way, you won't care order of them.
findroot_auto.sm (4,48 KiB) descargado 1212 vez(es).
sergio 11/5/2022 16:22:00, churichuro 11/5/2022 21:11:00
#11 Publicado: 12/5/2022 8:44:12
For your example, make it algo style for local infinite use.
Observe ... sols:=U^-1*V is universal outside of Smath Plugin(s)
... your question about order of vars
solutions are by convention in descending order of the pair wise u, v
no matter the names you give.
I can't explain the decimals difference between MCD 11/Smath.
There are other constants that can't be found exactly ...
Pitot constant, Goat radius constant ...
That remark applies to any solvers [Smath and wrt any CAS]
The U^1*V is the core component of the Cholesky solver
as applied to fitting model function to a data set.
In that case, best fit is obtained by iterating the Genfit.
Chers ... Jean.
#12 Publicado: 12/5/2022 9:46:19
... here, you can push the cork in the bottle to accommodate irrational pi.
as well ignore epsilon.
#13 Publicado: 12/5/2022 10:11:31
... as it looks, the max I could push the cork in the bottle
y≡0.279339266990994 ... sanity f(x,y,z)=-0.000000000001344
Confirms impossible exactly solving irrational numbers.
#14 Publicado: 12/5/2022 18:51:29
Grupo: Moderator
Long word short, there is an order for vars.
You can either avoid it manually or automatically.
It is up to users choice which suits them most.
Either one has advantages over other.
#15 Publicado: 15/5/2022 8:04:08
John
John
Thank you all so much!
a nice forum
#16 Publicado: 15/5/2022 11:21:14
churichuro
churichuro
29 me gusta en 79 mensajes.
I never thought the time would come when I would become an expert at ignoring specific comments on a forum...thanks Jean!
Oscar Campo 16/5/2022 14:07:00
#17 Publicado: 15/5/2022 13:20:51
Thank you all so much !
Solving is very important in Engineering Projects.
Reserve ... solve, roots, FindRoots and more to specific applications
Solving a square matrix goes via the conventional solver, no flaw.
This didactic document has been refreshed.
Solve Algebraic, MULTISOLVE DIDACTIC.sm (21,05 KiB) descargado 1288 vez(es).
#18 Publicado: 15/5/2022 15:26:39
...Thanks Jean!
Many of the advanced Smath documents are join venture.
Adapted/exemplified from various sources.
Download: Samples, Utilities Most used_3.
If something is not clear, please don't hesitate.
You have more, please offer.
Take care Amigo ... Jean.
#19 Publicado: 15/5/2022 15:34:46
Grupo: Moderator
No churichruo, dont.
If you will post same worksheets 600 times, (satire here)
and then you will tease how less another one contributed,
and how your post statistic is 18.3% of entire forum,
Please don't.
You will just make a fool of yourself.
Oscar Campo 16/5/2022 14:08:00
#20 Publicado: 16/5/2022 10:35:46
Do you mean churichruo will make a fool of himself
from reputed contributors in this document:
Mathsoft, Robert Adair, Carlos, Martin, Viacheslav, Romberg,
Riemann FD, Hermite Polyline, Legendre, Gram_Schmidt,
Guiseppe Borzi [simplex], Mathsoft Collaboratory Convolution ...
I will add Fresnel [Clothoid].
churichruo wrote Tanks Jean
