Create a graph with x-y plot
Create a graph with x-y plot - Mensajes
#1 Publicado: 11/2/2023 6:35:47
Beyaz
Beyaz
0 me gusta en 19 mensajes.
Hey guys,
im trying to plot my function with x-yplot (addon) but it doesnt work. I will be happy if can someone can help me.
i define two functions (with If-clauses) and now I have to put it in x-y-plot.
Thanks for helping
Pfahlsetzungslinie.sm (101,89 KiB) descargado 1371 vez(es).
#2 Publicado: 11/2/2023 9:51:05
I define two functions (with If-clauses) and now I have to put it in x-y-plot.
1. Start by the first red instance ... assign the demand.
2. For the plot Units don't match
3. Check if your incomplete Bolean is OK ... here shown complete.
4. What is mPa
#3 Publicado: 11/2/2023 11:27:05
Grupo: Moderator
If you want to plot, you have to eliminate units.
Either by writing a unitless function, or using units while plotting.
I would rather second one.
Pfahlsetzungslinie.sm (112,67 KiB) descargado 1415 vez(es).
Click to enlarge
#4 Publicado: 11/2/2023 14:22:20
Beyaz
Beyaz
hey guys thanks. (i tryed to give you a thanks but i always get an error)
it works now. Ive realized my mistakes.
i have 2 more question.
1. is it possible to rotate the graph or function? I wanna switch x and y axis
2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2
//sorry for my bad english
#5 Publicado: 11/2/2023 16:44:13
2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2
I understand 1 ... 2 Not clear.
#6 Publicado: 11/2/2023 16:46:06
... once the discrete data set in hand,
you can rotate by any angle as desired.
#7 Publicado: 11/2/2023 17:58:06
If I understand: once the discrete data set in hand,
very easy to range between Mi/Max.
Produce the discrete data set, I will terminate.
#8 Publicado: 12/2/2023 1:43:27
... i have 2 more question.
Hi Beyaz.
1. Yes. For example you can use this technique over your functions
xy-yx-plot.sm (7,16 KiB) descargado 1348 vez(es).
2. Yes. For example you can try to learn about how to use setprop in an XY plot region.
#9 Publicado: 12/2/2023 7:09:44
Beyaz
Beyaz
question 2: solved after find this
https://en.smath.com/forum/yaf_postsm57205_X-Y-Plot-Region.aspx
but to rotate the graph like this it didnt work. i tried your suggestions. Pfahlsetzungslinie1.sm (80,01 KiB) descargado 1373 vez(es).
#10 Publicado: 12/2/2023 8:47:18
Hi. You need to specify the XYPlot index. This is how to swap axis coordinates, and reverse the y-axis. I reduce the number of points in the XYPlot to 50.
Pfahlsetzungslinie1.sm (87,42 KiB) descargado 1388 vez(es).
#11 Publicado: 12/2/2023 9:12:08
But to rotate the graph like this it didn't work.
I tried your suggestions.
You haven't produced the discrete data set.
Wanna Rotate.sm (14,34 KiB) descargado 1324 vez(es).
#12 Publicado: 12/2/2023 14:23:09
#13 Publicado: 13/2/2023 7:13:49
Grupo: Moderator
You can also use a rotation matrix.
It works on both 2DPlot an XYplot.
churichuro 13/2/2023 16:11:00
#14 Publicado: 13/2/2023 10:41:33
Rotate XY.sm (486,01 KiB) descargado 1371 vez(es).
#15 Publicado: 13/2/2023 15:07:49
Beyaz
Beyaz
thanks all of you guys.
now my smath tool is perfect. thanks for helping.
