1 páginas (8 elementos)
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - Mensajes
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127,5 KiB) descargado 1202 vez(es).
Thank you
Thank you
WroteSome direction would be appreciated.
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150,39 KiB) descargado 1219 vez(es).
... here is a more complete search.
ADR brute force augmented.sm (159,59 KiB) descargado 1187 vez(es).
WroteSome direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix
Don't miss the Truth Table Companion in Samples.
WroteAaah now I get what you meant.
This should solve your problem.
Deleted previous post.
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
WroteIs this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19,1 KiB) descargado 1207 vez(es).
