multiplay worksheet / pages
multiplay worksheet / pages - using more then one page / worksheet - Mensajes
#1 Publicado: 2/7/2016 11:43:27
Hanina
Hanina
0 me gusta en 3 mensajes.
How to create a work that need room larger then single page (worksheet)?
Is it possible referring items in one page from another page?
#2 Publicado: 2/7/2016 13:18:28
Not sure if I understand your problem. A "work sheet" can contain
as many pages as needed to contain the project. Assume the first
part of the project has filled or nearly filled 1rst page, as soon as
you add more of the project, it gets another page 2. What is the max
pages a work sheet can contain, don't know.
An Smath work sheet is like Mathcad, i.e: a collection of pages.
Cheers, Jean
#3 Publicado: 2/7/2016 13:25:13
127 me gusta en 342 mensajes.
In the "extensions" section you can see the plugins "includes" and "run". They are very useful to extend and interact with other sheets. Other plugins interact with the outside.
#4 Publicado: 2/7/2016 14:21:34
Hanina
Hanina
Thanks seems that what I looking for create hierarchy between different pages - so one page can include basic model and user define functions that I will use in different works
But I don't know where to find the "Extension" section you talk about - didn't find it in the list of plugins may be I miss somting
Hanina
#5 Publicado: 2/7/2016 16:09:56
Hanina
Hanina
I found the plugin copy the DLL to smath plugin dir but when run smath get error: The following plugin cannot be start GUID.... Access to path c:\Program Files (x86)\SMath Stdio\plugins\log.txt is denied
#6 Publicado: 2/7/2016 16:59:10
Grupo: Super Administrator
Please, never put/edit/remove any files from c:\Program Files (x86)\SMath Stdio\.
Use Tools > Plugins from SMath Studio main menu, switch to Online gallery and install plug-in:
P.S.: Do not forget to revert changes from c:\Program Files (x86)\SMath Stdio\plugins\.
#7 Publicado: 2/7/2016 19:29:06
Thanks seems that what I looking for create hierarchy between different pages "work sheets or document" - so a "project worksheet" can include basic model and user defined functions that I will use in different "work sheets"
What you wrote is what I read in "...", is it ?
I don't understand what PompelmoTell means wrt "Extensions" to your request.
Smath 5346 [April 2014] can fetch modules from other work sheets by the function
menu f(x) include(,) as demonstrated in the two attached. IMHO, I would discourage
starting with this idea. This approach is not professional as you will soon end
with quite a micmac of Smath documents. Smath is like Mathcad: it gets his power
from lot of user built modules.
On the other hand, when you will require help from the forum, that may complicate
the matters of retrieving both or more than two companions. Maybe the latest versions
cope with this approach. What's better than a stand alone document, complete and
autonomous by itself that you can *.PDF for publishing to any audience.
Put your "referenced modules" at the top of the work sheet project,
collapse that region for a clean document.
Genfit Algo Include.sm (12,99 KiB) descargado 1234 vez(es).
Genfit Algo Include Test.sm (16,54 KiB) descargado 1232 vez(es).
