Units don't match problem
Units don't match problem - Mensajes
#1 Publicado: 6/8/2016 13:09:41
Eduardl
Eduardl
0 me gusta en 5 mensajes.
Hi everybody, I have a units problems that I can´t solve. Can be a bug?
Units
Here is my file.
Documento1.sm (29,86 KiB) descargado 1360 vez(es).
Libro2.xlsx (8,17 KiB) descargado 985 vez(es).
Thanks in advance
Eduar
#2 Publicado: 6/8/2016 13:42:29
Grupo: Moderator
Hello Eduar,
nope, is not a bug; the problem is in your second boolean comparison. You have nested a boolean less or equal in the left argument of a boolean less -> the first returns 0 and 1, then this result is compared with the second argument of the boolean less (and here you were lucky because you got 1 - when you get 0 you can't see the error)
You have to use the boolean AND to chain two boolean comparisons
Alternatively it is possible to use the function lelt(3) from the plug-in "Custom Functions"
#3 Publicado: 6/8/2016 13:57:06
Eduardl
Eduardl
Thanks Davide, I´ll try it.
And thank you for the plugin.
Eduar
#4 Publicado: 6/8/2016 14:46:02
Eduardl
Eduardl
Eduar
Hi Davide, your method works fine. But I still have problems with the resolution of the division.
I don't understand, the result is a vector.
Sorry for the question, I'm a newbie in Smath.
#5 Publicado: 7/8/2016 5:25:18
Grupo: Moderator
Don't worry; vectorize() is intended to apply to all the vectors' elements functions normally intended to work with scalars without using loops. In your case you have 2 ways:
1) use the loop; in this case vectorize() is not needed, remove it and everything should works
2) use vectorize(); in this case you have to remove all the references to the matrix elements. Note that in your case you have to pre-process or post-process the elements where Mu doesn't meets the requirements
Eduardl 8/8/2016 15:33:00
#6 Publicado: 7/8/2016 8:55:06
Eduardl
Eduardl
You are right!
Thank you Davide.
I hope I can contribute to the community in the future.
Eduar
#7 Publicado: 9/8/2016 11:39:29
EduardI,
If you have to select elements in the vectorise,
the Dot function may be the tool... just posted.
#8 Publicado: 9/8/2016 11:44:18
Eduardl
Eduardl
Jean, thanks for the tip. I'm learning fast thanks to you guys!
#9 Publicado: 10/8/2016 0:36:46
"Jean, thanks for the tip. I'm learning fast thanks to you guys!"
How do you know you are learning fast ? !
This type of indexed construction has many variantes, most useful.
For instance: randomly select reasonable number of data points from
an overpopulated collection to be fitted ...
