Conditionally Formatted Labels vs Insert Writer Region
Conditionally Formatted Labels vs Insert Writer Region - How to insert math symbols: Summation, Integral, Radical Sign, etc - Mensajes
#1 Publicado: 11/11/2021 14:27:23
Fran Lee
Fran Lee
1 me gusta en 44 mensajes.
1 - Reference Book Correction:
Help > Reference Book > Plug-Ins > Conditionally Formatted Labels
Reads: Menu > Insert > Formatted Labels
Should Read: Menu > Insert > Controls > Formatted Labels... right?
2 - I have SMath Studio Handbook 0.99.6671, is that the latest?
Isn't there another "Handbook" often recommended? If so what is that?
3 - I can't enter the square brackets at the beginning and end of the CFL defining... like...
[" OK " "white" "red"]
The CFL widget only lets me enter parentheses, not square brackets.
Is there a trick?
4: How can you enter math symbols like the summation or integral symbols or radical symbols?
a. In CFL?
b. In Writer Region?
5 - How to add a clickable button to change the color of a Writer Region or a CFL?
(someone shared Background.sm with me that has this example)
6 - To include a picture in the post do I upload it to the forum post or link to it on a shared drive?
Sorry for all the questions but this will be helpful to me.
Thanks guys!
#2 Publicado: 11/11/2021 14:53:13
Grupo: Moderator
1 - Reference Book Correction: ... right?
Right.
2 - ...is that the latest?
It is latest.
Is there a trick?
Use matrix, square brackets are matrix.
4 - How can you enter math symbols?
a. In CFL?
Please detail your question.
Where do you want to enter symbols?
5 - How to add a clickable button?
There is Radio Buttons which can be used.
6 - To include a picture in the post?
Use attach symbol while entering posts.
Choose your picture file or suitable file.
Click to upload. It will be added to your post.
Check the example file for your questions.
CFL with radiobuttons.sm (4,29 KiB) descargado 1321 vez(es).
#3 Publicado: 11/11/2021 15:26:02
1. Click Background to open the your pre-selected background(ssss...)
2. Click your selection
If your selection is active, it will background any Smath region.
Search "Bullets" in Samples from me, many memo code background.
#4 Publicado: 11/11/2021 16:40:02
Grupo: Moderator
Not related with neither topic nor 5th question.
I don't know a way to change color of a Writer region with a button.
You can use CFL for this scenario. CFL's purpose is this actually.
Change its content, foreground and background colors with variables.
And you can use Radio Buttons to alter a variable.
And use that variable value in CFL's if() or cases().
#5 Publicado: 11/11/2021 17:07:13
Fran Lee
Fran Lee
OK, Great! I understood most of the answers... I think :-)
I still can not find out how to create a square area to make it a clickable button.
Do I need the "Control Region" Plug-in to make a clickable button or what?
Jean, you said
Citar
....Where are "samples from me"?
Overlord,
From your answer I was able to create this... (and thanks to Jean for encouraging me to explore CFL)
CF_Label_Tutorial.sm (4,35 KiB) descargado 1271 vez(es).
You guys let me know if I got it right.
Also, I'm going to read your answers once again to see if I missed anything.
Finally, how do I delete a file I uploaded? The first picture I uploaded was too big so no need for it to waste disk space.
Thanks !
#6 Publicado: 11/11/2021 17:31:06
Grupo: Moderator
There is no option/support/plugin/etc for a clickable button in SMath.
There are checkboxes, radio buttons for clickable situations.
What you want is a Button as in Excel visual basic macros.
We don't have that in SMath, yet.
And you can't use CFL to make it behave as a button.
Its job is to create textboxes/labels which change with conditions.
You got it right and made your first CFL.
But because it is not depended to an if() or cases(), now it is a static label.
Which is fine, but you can achieve that with a text region too.
Click on "My profile" at top-right of SMath forum.
There is Attachments section on the left list.
You can delete you desired attaches from there.
oscar mauricio 12/11/2021 9:17:00
#7 Publicado: 11/11/2021 18:18:10
Fran Lee
Fran Lee
Thanks Overlord.
Insert > Checkbox was what I was looking for.
The name "checkbox" threw me off.
Here is what I was trying to replicate as a learning experience.
Background.sm (5,13 KiB) descargado 1334 vez(es).
I'll take a shot at it now that I have discovered the Checkbox.
I also want to try and replicate the file you shared... just so I am sure how to do it.
Thanks for the help !
#8 Publicado: 14/11/2021 21:52:07
Fran Lee
Fran Lee
In overlord's post near the beginning of this thread he provided a sample...
CFL_with_radio_buttons.sm
I was trying to replicate it from scratch to see if I could do it...
- I created the 3 radio buttons...
- I created an "expression" with 3 placeholders vertically
- Then made a 1x2 matrix for each of those 3 placeholders
- Then made a 1x3 matrix for the first element in the 1x3 matrix
But it doesn't look the same as his... mine looks like this...
Question 1: How were the 3 lines in the CFL Created?
Question 2: How was the "if" statement created without an "else" ?
Also, when I downloaded and launched his example it told me he was using a newer SMath version
My SMath version is 0.99 (build 7822) Date 6/1/21. on Windows 10 Pro
Question 3: If there is a newer version/build would I install it on top of my existing version or first uninstall the current version of SMath?
Thanks for the help folks !
#9 Publicado: 15/11/2021 0:08:07
Grupo: Moderator
with cases() function.
With cases() function.
It is useful for multiple if situations.
No need for uninstall.
It will install on top of your SMath.
You settings and plugins shall be preserved.
You will need to uncheck beta exclude.
#10 Publicado: 15/11/2021 18:45:04
Fran Lee
Fran Lee
a - Can I install the beta to run separately without installing of the latest stable version?
b - How stable is the beta version?
c - Is SMath a "stand alone" program or does it install using the Window registry, etc?
Thanks.
#11 Publicado: 15/11/2021 19:16:49
Grupo: Moderator
Thanks.
a - You don't need to install beta. You can set smath to act as portable.
All extensions, settings, etc will be kept in that directory.
Just download SMathStudioDesktop.0_99_7921.Mono.tar.gz or any other build.
Extract it to a directory. Create an empty file "portable.version"
That smath will be portable sitting along with your installation.
b - Beta versions are quite stable.
In fact everybody uses them, excepts some oddballs.
c - It uses Roaming directory under %APPDATA%.
As far as I know keeps settings, plugins visa versa under Roaming/Smath directory.
Sure it shall use registry for file extensions, uninstall information, etc.
If you make it portable as described above, it will keep all its data under that directory.
#12 Publicado: 15/11/2021 21:29:14
Fran Lee
Fran Lee
OK, I downloaded MathStudioDesktop.0_99_7921.Mono.tar.gz and used 7zip to get it all out into a folder a advised.
- I then created a empty file portable.version in the same directory
- I then double clicked SmathStudio_Desktop.exe to launch the program but... suprise...
... SMath Solver opened up. I'm unsure what Solver is unless it is the engine SMath uses to solve equations...
Question 1: Is "Solver" the beta MathStudioDesktop.0_99_7921 ? Is it the latest SMath version?
Question 2: I was advised..."You will need to uncheck beta exclude" ...
... where is that checkbox located? Did I miss along the way or what?
Question 3: Re cases function... used in overloards cfl_with_radiobuttons.sm early in this thread...
- I created a CFL and for the placeholder...
- I created a cases function but it only created one "if" case followed by "otherwise on the next line...
How to create more if cases? (I banged on it and made numerous attempts and scanned the custom functions thread... but no joy.)
Thanks
#13 Publicado: 15/11/2021 23:08:04
1. Get the basic if/otherwise [Cases]
2. Click on the the RHS place holder
3. Enter twice
#14 Publicado: 16/11/2021 1:14:48
Grupo: Moderator
Question 1: Is it the latest SMath version?
It is latest.
Now we have Solver and Writer.
Solver is traditional smath interface.
Writer has more like Ms Word style.
Question 2: where is that checkbox located?
Click local storage in plugin window, there you will see it.
Question 3: How to create more if cases?
Use arguments separator. "," or ";" which of you had set.
#15 Publicado: 16/11/2021 12:12:11
Fran Lee
Fran Lee
Sorry, not working
Question 1: I must be misinterpreting your instructions... can you advise?
Question 2: I wonder if my Custom Functions plugin is an old version?
To update a plugin must I delete the plugin and re-download/install it?
Thanks for sticking it out with me.
#16 Publicado: 16/11/2021 13:56:39
On that place holder top right ... double click coma keyboard
Try it ... Cheers ... Jean.
#17 Publicado: 16/11/2021 14:46:09
Grupo: Moderator
Hit comma again, a new ifline shall be added to cases.
My argument separator is semicolon, so don't be confused.
According to your screenshot, yours is comma.
cases()
Question 2: must I delete the plugin and re-download/install it?
Not need to delete.
Plugins shall be automatic updated.
#18 Publicado: 16/11/2021 19:03:43
Fran Lee
Fran Lee
Da Da!
(Credit to overlord and Jean Giraud for guiding me along the way.)
CFL_RadioButtons_Step_by_Step.sm (13,17 KiB) descargado 1255 vez(es).
Hopefully this step-by-step will help other newbies.
PS Let me know if I made an error... but it looks to me like it's working.
#19 Publicado: 16/11/2021 21:15:17
The code Samples Formatted Label Symbol(s) is more productive.
Unfortunately, a recent bug does not access Settings for sizing.
#20 Publicado: 16/11/2021 21:45:13
Grupo: Moderator
This is not an error but it needs a clarification.
Setting column in radiobutton shall tell region which column shall be used for source.
In screenshot below you can see there are two columns of data.
If you set nothing or a nonexisting column, it will take first column.
If you set an existing column, it will use that particular column of the matrix.
