How to enforcing simbolic evaluation?
How to enforcing simbolic evaluation? - Mensajes
#1 Publicado: 20/2/2021 3:17:40
netsonicyxf
netsonicyxf
2 me gusta en 79 mensajes.
Even if the variable have been defined.
E.g. how to get x=(a+b)(a-b)even if a=1, b=2
Archivo no encontrado.Archivo no encontrado.
#2 Publicado: 20/2/2021 9:39:43
#3 Publicado: 20/2/2021 10:20:42
netsonicyxf
netsonicyxf
Thanks, but I want to know how to get U=(a+b )*(a-b ), even if a=1, b=2 is on the top
#4 Publicado: 20/2/2021 12:01:23
Thanks, but I want to know how to get U=(a b )*(a-b ), even if a=1, b=2 is on the top
I simply don't understand your request.
Read Martin handbook, to learn using Smath.
#5 Publicado: 20/2/2021 13:02:11
Martin_B
Martin_B
22 me gusta en 84 mensajes.
I think the only way is to delete the defintions by using Clear(a;b)= .
#6 Publicado: 20/2/2021 13:15:24
I think the only way is to delete the definitions by using Clear(a;= .
No need, algo is self clearing.
#7 Publicado: 20/2/2021 17:18:06
#8 Publicado: 21/2/2021 1:25:56
Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation:
#9 Publicado: 21/2/2021 9:24:07
netsonicyxf
netsonicyxf
really wish Smath can perform like MathCAD
#10 Publicado: 21/2/2021 11:00:13
#11 Publicado: 21/2/2021 11:10:37
netsonicyxf
netsonicyxf
Thanks Jean.
BTW, MathCAD doesn't need to do clearance.
#12 Publicado: 21/2/2021 12:00:32
True for that little example. More advanced stuff needs be cleared as well.
The symbolic arrow was demanded but not implemented.
#13 Publicado: 21/2/2021 13:27:04
Grupo: Moderator
The only way is to define the variables after the expression, then you can show the expression using Clear. The other way doesn't works because when values are set before the expression, the values are stored in memory, not the variable names.
#14 Publicado: 21/2/2021 13:28:15
Thanks Jean.
Hi. It needs. That is the mean for a:=a and b:=b, which clear a and b only for symbolics, but not for numerics. If you want to show the symbilic value stored in x cleaning a and b after you define x, you can use line() in the definitions:
Also notice that you need to eval Clear(a, b ) = 1, if not SMath not recognize that as an instruction.
Davide Carpi 22/2/2021 5:37:00
