DISCARDED: SMath Studio 0.99.6647 (14 March 2018) - Mensajes
Ofrece numerosas funciones de cálculo y una interfaz de usuario completa, traducida a unos 40 idiomas diferentes. La aplicación también incluye una obra de referencia matemática integrada.
La aplicación puede ampliarse fácilmente según sus necesidades. La herramienta integrada de gestión de extensiones permite acceder a cientos de recursos, tanto oficiales como de terceros, que incluyen: ejemplos de uso, complementos (plug-ins), aplicaciones basadas en SMath Viewer, fragmentos de código, traducciones de la interfaz, libros interactivos, manuales y tutoriales.
Descargar
SMathStudioDesktop.0_99_6647.Mono.tar.gz (1,28 MiB) descargado 2503 vez(es).
SMathStudioDesktop.0_99_6647.Setup.msi (2,15 MiB) descargado 4740 vez(es).
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
WroteuMath Files Plugin appears to be broken with new release.
Thank you! Fixed and new plug-in version uploaded.
Thanks,
Jason
WroteArea controls seem to have been adversely affected with this build.
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
C6 Channel Shear Tab.sm (228,91 KiB) descargado 1666 vez(es).
Do you have the initial version?
WroteI experienced problems similar to those of Jason.
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
Jason
Channel Shear Tab.sm (228,88 KiB) descargado 1625 vez(es).
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Thank you very much for the report and your help!
