Ode solvers implementation
Ode solvers implementation - Mensajes
#1 Publicado: 29/11/2018 19:09:04
Hi. I can't reproduce this in SMath.
Archivo no encontrado.Archivo no encontrado.
Вячеслав Мезенцев 30/11/2018 3:25:00, Radovan Omorjan 30/11/2018 5:06:00
#2 Publicado: 29/11/2018 23:48:00
1/1 in Smath 6179, proof: the snippet.
Cheers Alvaro
Integrate with ode solver.sm (29,07 KiB) descargado 1316 vez(es).
#3 Publicado: 29/11/2018 23:59:54
You may not be able to implement the Mathcad bloc Given/ODEsolve.
ODEsolve is based on linterp. That is the first point.
The other point is that in Mathcad "linterp(x)" is a scalar function.
In Smath: ainterp, cinterp, linterp are simply interpolation fncts
They are not scalar functions. How does it reflects in ODEsolve ?
In Smath, ln(x), exp(x), ... are scalar from source code.
I tried to make cinterp scalar like in Mathcad, not to avail.
Please, persist on such a beautiful idea.
#4 Publicado: 30/11/2018 1:16:48
This document was essentially designed to plot scalar the derivative on canvas,
as well as get a discrete export. Also included: the scalar quadratic.
Spline Deriv Infinitesimal.sm (70,87 KiB) descargado 1330 vez(es).
#5 Publicado: 30/11/2018 2:31:22
Hi Jean. Actually not, just the solver, without the given.
I found how to call the odesolver, with D(x,y)=[f(x)].
This method is much more faster than the direct integration.
But remains the ln(0) error, which seems to be a bug in the odesolvers, because zero isn't in the domain range.
Integrate with ode solver.sm (10,17 KiB) descargado 1257 vez(es).
Radovan Omorjan 30/11/2018 5:10:00
#6 Publicado: 30/11/2018 3:35:52
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
The zero point is used to determine the dimension of the vector D(t,x) at runtime (D(0, x0)). The size of the system must be determined for the further operation of the numerical algorithm. It seems that it would be correct to substitute the beginning of the interval. I will try to change this. Also, if possible, I will support the one-dimensional case.
A 4 usuarios les gustó este mensaje
sergio 30/11/2018 5:43:00, frapuano 30/11/2018 5:37:00, Alvaro 30/11/2018 4:53:00, Radovan Omorjan 30/11/2018 5:06:00
#7 Publicado: 30/11/2018 5:01:06
Thanks Viacheslav. It's amazing the effort that you and the others plugins developers put in enhance SMath, with very spectacular results.
#8 Publicado: 30/11/2018 12:29:42
Buenos dias Alvaro !
ln(0) was introduced in Mathcad 11 soon after release via update [from recollection]
There is more in the attached, specially wrt parametric D(,,,).
ODE 0_Model General.sm (29,47 KiB) descargado 1291 vez(es).
#9 Publicado: 30/11/2018 12:34:54
#10 Publicado: 30/11/2018 15:36:38
... refreshed version wrt explore all solvers.
ODE 0_Model General.sm (38,44 KiB) descargado 1253 vez(es).
Alvaro 30/11/2018 15:54:00, frapuano 30/11/2018 17:58:00, Davide Carpi 3/12/2018 21:18:00
