1 páginas (4 elementos)
Syntax Error in Roots Function - I receive a syntax error in the "roots(2)" function - Mensajes
Please help me understand what I am inputting incorrectly. I have used the "roots(2)" function before. Also, if there is a more simple way to solve the unknowns let me know. I was trying to avoid linear algebra as getting the unknowns in expanded form would be difficult.
With fewer variables, it worked fine as shown in the first image of the PDF
Doc1.pdf (84,85 KiB) descargado 765 vez(es).
Thanks for the Help!
WrotePlease help me understand what I am inputting incorrectly. I have used the "roots(2)" function before. Also, if there is a more simple way to solve the unknowns let me know. I was trying to avoid linear algebra as getting the unknowns in expanded form would be difficult.
You possibly wrote something wrong.
It did work at my computer.
Next time please provide your doc.sm file too.
It will be much more easier to understand the problem.
And no one would need to write your entire sheet from scratch.
doc.sm (18,14 KiB) descargado 1270 vez(es).
sergio 26/2/2022 5:46:00
WroteYou possibly wrote something wrong.
overlord:
Thank you for the quick reply. Sorry I was only able to revisit this today, and sorry I did not attach the original document.
I tried it a few more times and changed some things around.
I removed the syntax error, but now the "roots" function endlessly calculates but never gives an answer. I have let it run for 15 minutes but no solution.
Have you experienced this issue before?
Attached is the actual document if you or anyone else would like to view it.
Thanks!
doc.sm (50,18 KiB) descargado 1275 vez(es).
