1 páginas (4 elementos)
Default Font size - Tools -> Options... does not change the font size - Mensajes
WroteWhen I change the font size to 12 under Tools -
"Changes will take effect after restart".
In a Smath work sheet, each region supports font size at will, from the Menu.
Very handy to reduce/enlarge some function/results.
WroteAfter I click the OK button and open the dialog box again the value changes back to 10.
In your Smath version the note is missing
"Changes will take effect after Program restart".
A very old issue, I'll take a look if can be easily fixed... the setting however is applied and available since you press ok (talking about recent versions)
