appimage in Debian (MX Linux) - doesn't work - Mensajes
but nobody mentioned my distro:
MX-23.5_KDE_x64 Libretto
I have downloaded appimage, made it executable and here is the result:
Citarbambuko@mx-elitedesk:~/Applications/SMath_Studio
$ ./SMathStudioDesktop.1_3_0_9126.x86_64.ubuntu-22_04.glibc2.35.AppImage
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Drawing.Printing.SysPrn' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:type: member null)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at System.Drawing.Printing.SysPrn..cctor () [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Drawing.Printing.PrinterSettings..ctor () [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Drawing.Printing.PrintDocument..ctor () [0x00011] in <728fbd68fe594062895e1f819791e76a>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Printing.PrintDocument..ctor()
at SMath.Environment.DesktopAppEnv..ctor (System.String appNameInternational, System.String appNameLocal, System.Version appVersion, System.Boolean isWebApplication, System.String applicationPath, System.Boolean randomizeInstallationId) [0x00019] in <9ea83db511ca44e3bef101076f6663b2>:0
at SMath.Environment.DesktopAppEnv..ctor (System.String appNameInternational, System.String appNameLocal, System.Type appType, System.Boolean isWebApplication, System.String applicationPath, System.Boolean randomizeInstallationId) [0x00013] in <9ea83db511ca44e3bef101076f6663b2>:0
at SMath.Environment.AppSettingsDesktop.SetupGlobalProfile (System.String appNameInternational, System.String appNameLocal, System.Type appType, System.Boolean randomizeInstallationId) [0x00000] in <9ea83db511ca44e3bef101076f6663b2>:0
at .. (System.String[] ) [0x0001d] in:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Drawing.Printing.SysPrn' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly:type: member null)
Restoring environment...
Can anybody help, please?
I made a couple of corrections for this appimage.
Maybe it works for your distro too.
https://en.smath.com/forum/yaf_postsm86402_AppImage-File-Crashes-on-Linux-Mint-v22.aspx#post86402
unfortunstely, no it doesn't work
WroteI have tried it before posting...
Then I will download liveiso of your distro.
And I will try smath on it with qemu.
Please standby...
hopefully we can get it working with Flatpak.
I am using Smath with https://usebottles.com/ at the moment but would prefer to avoid this complication....
WroteThank you,
Probably, why it doesn't work is glibc/libgdiplus mismatch.
I will look further but most times problem is this.
I extracted it and tried to run but it gives errors.
No wonder why appimage not working, mono executable doesn't work too.
thank you
Email notices about your post give the following link:
http://en.smath.com/forum/yaf_postsm86558_appimage-in-Debian--MX-Linux.aspx#post86558
trying to use it leads to nowhere...
it should be:
https://en.smath.com/forum/yaf_postsm86558_appimage-in-Debian--MX-Linux.aspx#post86558
the same goes for SMath webpage - all the links there are also http instead of https.....
I guess it might also be to do with the way my browser is set?
I tried stable/nightly versions of mono.
Neither appimage or smath mono works on debian.
Only thing I didn't try is full recompile of mono.
As I have said many times;
Debian and/or its derivatives are not suitable for desktop usage.
